Shifted steering wheel - BMW Forum - BimmerWerkz.com
Old 01-20-2004, 05:34 PM   #1 (permalink)
dubumb's Avatar
dubumb is an unknown quantity at this point
Send a message via AIM to dubumb
Hi,
Problem that i've had since i got the car, but didnt address it until now... When my wheels are straight like this (imagine these are wheels lol) | | My steering wheel is shifted about 1/8th of a turn counterclockwise. So, how can i fix this? do i need to have my whole alignment done? It's nothing important really, it drives straight and smoothly, it's just kinda annoying....
<center>
<img src='http://www.ownster.com/forums/uploads/post-10-1076044411.jpg' border='0' alt='user posted image' />
<a href='http://www.cardomain.com/id/dubumbz' target='_blank'>my car @ cardomain....</a>
<a href='http://www.ownster.com/' target='_blank'><img src='http://www.bmw-forums.com/forum/uploads/post-4-1075256000.gif' border='0' alt='user posted image' /></a>
&lt;/center&gt;
dubumb is offline   Reply With Quote
Old 01-20-2004, 05:37 PM   #2 (permalink)
Maz
Maz is an unknown quantity at this point
Send a message via AIM to Maz
I am pretty Sure alignemt would fix this problem, its nothign severe!! I have seen people who's steeering wheels are 1/4 the way to side when going straight!!
Maz is offline   Reply With Quote
Old 01-20-2004, 05:46 PM   #3 (permalink)
chuck540owner is an unknown quantity at this point
Probably was aligned incorrectly. When the toe adjustment is done any adjustment should be divided between the left and right tie rod's. This keeps the steering wheel centered. If the guy doing the alignment is in a hurry he might adjust only one of the tie rod's. The toe might still be correct but the steering wheel is off centered.
If you get it aligned make sure you tell the tech about the steering wheel.
chuck540owner is offline   Reply With Quote
Old 01-20-2004, 06:00 PM   #4 (permalink)
TECH's Avatar
An alignment will correct it. If an alignment is done correctly, the wheel should be straight, unless the car has a tire pull, and you have to constantly correct it all the time.
Now, the alignment machine we use at work does a good job, but many times the steering wheel doesn't come out perfect-like I want it to. For some reason, they never could get the thing to keep the steering wheel straight.
If you want, you can pull off the steering wheel, turn it one notch the way you need, and put it back on.
Unofficial fix.
Old 01-20-2004, 06:24 PM   #5 (permalink)
dubumb's Avatar
Unofficial fix.
thanks a lot for all of the info, and tech, how can i go about pulling off the wheel?
&lt;center&gt;
&lt;/center&gt;
Old 01-21-2004, 02:25 AM   #6 (permalink)
wiseman168 is an unknown quantity at this point
:P
Maybe you already equipped with the New 5 "Active Steering" LOL
wiseman168 is offline   Reply With Quote
Old 01-21-2004, 10:20 AM   #7 (permalink)
dubumb's Avatar
Originally posted by wiseman168@Jan 21 2004, 04:05 AM
:P
lol, not quite.
&lt;center&gt;
&lt;/center&gt;
Old 01-22-2004, 10:08 PM   #8 (permalink)
EXtech's Avatar
If you search around you can find a shop with top of the line equipment, Hunter has their new machine and program with a steering sweep in it that allows for proper steering wheel alignment. It can be done.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
Steering Wheel Upgrade Options gmal 5-Series (E12,E28, E34, E39, E60) 0 10-28-2004 08:25 AM
E36 Steering Wheel MrTwisties 3-Series (E36) 6 07-23-2004 01:36 AM
Triangle 3 spoke Sport Steering wheel woobiee Classifieds Sell & Buy 11 10-03-2003 03:08 PM
