SES light, lots of codes- One Air flow Sensor - BMW Forum - BimmerWerkz.com
Old 08-07-2012, 10:20 PM   #1 (permalink)
cjscopp's Avatar
Car: 2002 525i and 1995 325i
cjscopp is on a distinguished road
163K miles, SES light has been on and off for a little while and I ignored it for too long. Finally got around to pulling codes and found lots of them. P0313-misfire cyl 3, P0183 fuel control limit bank 1, P1085 fuel control limit bank 2,
P0171 lean bank 1 and P0174 lean bank 2. Car ran fine with only a slight "lope" on cold start for 3-4 seconds then everything was great. Searched lots of sites and the consensus is a bad MAF sensor. Rolled the dice and picked one up this afternoon and installed it and immediately the SES light went out. Thank God for the internet! Now I have to go after the right front wheel speed sensor that has the DSC light on (code 006). I have neglected the girl for too long and it's time to get her back in shape.
cjscopp is offline   Reply With Quote
Old 08-21-2012, 09:46 AM   #2 (permalink)
cjscopp's Avatar
Finally got around to doing the wheel speed sensor but the DSC light is still on, damn...Have found lots of info on the trio of DSC ABS and brake warning lights but not much on just the DSC warning light. ABS works fine but traction control does not. Speedo and cruise is also fine so i am stumped. Looked at module masters web site and read on the needed rebuild of the controller but I keep thinking since everything else works fine the odds of the ABS/DSC controller being bad is low. During this whole mess I accidentally hit the rear shade button next to the DSC button and the drivers side pivot broke. Ordered the aftermarket aluminum pivots yesterday and will get to that project this weekend. I hope to find some tips on the DSC issue from all my friends here.
Old 08-21-2012, 04:13 PM   #3 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Theirs a speed sensor in the diff as well. Check that one.
Click HERE to see my E36 Blog
Old 08-29-2012, 03:06 PM   #4 (permalink)
cjscopp's Avatar
Well, sh*!, the SES light came back on last night! Gonna have to pull the codes again and see what the old girl is up to now. Thought we were good to go for a while but apparently not, it's been 3 weeks with the light out and all seemed to be well. Almost 165K miles and she is getting temperamental and bitchy. Anyone ever had a new AFM go bad after 3 weeks???
Old 09-08-2012, 05:57 PM   #5 (permalink)
cjscopp's Avatar
SES light went off last night and has been off all day. Quickly took it in for the dreaded California Smog Check while the SES light is off so I can renew the reg. Gonna have to buy the scnner software for my laptop so I can see what's going on.
Old 09-10-2012, 03:12 PM   #6 (permalink)
cjscopp's Avatar
WTF??? The SES light came back on this morning. On, off, on off. Never seen anything like this. I am not getting much response here so apparently nobody else has dealt with this issue. Thought I had it all rapped up with the AFM but obviously not. Since I don't have a scanner, I will have to have the codes pulled and start all over. Damn...
Old 09-11-2012, 10:17 AM   #7 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Do you have auto parts stores that scan the car for free?
Old 09-27-2012, 05:36 PM   #8 (permalink)
cjscopp's Avatar
Looked into the Autoenginuity laptop based scanner software and it looks like a neat deal. Anyone else used this software?
Old 09-27-2012, 10:45 PM   #9 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
I would recommend the BMW Carsoft software. The required cables are available off Ebay for a reasonable amount. The software can be found as a free download. All you need is a laoptop with a serial port.
Old 02-15-2013, 07:55 AM   #10 (permalink)
cjscopp's Avatar
After ONLY 6 months I think I finally have this one solved, bad #3 cylinder coil. Had a P0313 misfire code with P0171 and P0174 lean bank one and two codes. Never did feel a missfire but apparently the whole thing is related to the coil. Weirder still is that I replaced that coil more than a year ago when I had the same po313 code but must have bought a bad coil (what I get for buying a cheap Kragen part). Scanner showed short term fuel trims above 10% so I have been looking for intake leaks but found none. Got me a good Bremi coil and put new plugs in while I was there and the old girl is back!
Old 02-18-2013, 07:42 PM   #11 (permalink)
cjscopp's Avatar
Hey Vader, can you give me a link to the free carsoft obdii software? can't seem to find what I think I need for free (yeah I'm cheap).
Old 02-22-2013, 08:46 AM   #12 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Heres one:
Download carsoft bmw - FilesTube
You will need the cable that connects from your laptop/computer to your OBC port. Those are available on ebay for pretty cheap.
2001 525i Lots of codes but driving perfectly adrian@candyjar 5-Series (E12,E28, E34, E39, E60) 8 08-24-2009 08:50 AM
check engine light on with codes for oxygen sensor accutechautomotive 3-Series (E46, E90) 3 04-15-2009 10:11 AM
Air Mass Flow Sensor skaowili 3-Series (E36) 2 07-31-2008 10:38 PM
mass air flow sensor peri 3-Series (E36) 2 02-15-2006 08:01 AM
Air Flow Sensor yellowtailtj M-Series (M1, M3, M5, M6) 0 01-04-2005 05:44 PM
