Service Indicator Reset? - BMW Forum - BimmerWerkz.com
Old 01-29-2006, 09:03 PM   #1 (permalink)
Fangs's Avatar
Fangs will become famous soon enoughFangs will become famous soon enough
I recently had an oil change done on my E39, and they forgot to reset the service indicator. I am 1.5 hours from the nearest dealer.
Is there any way to reset this yourself, or (as I suspect) does it require a special tool?
Argh:
<span style='font-size:12pt;line-height:100%'><span style='color:blue'>I don't drive fast,</span> <span style='color:red'>I FLY LOW</span></span>
'99 323i
'02 540i
Fangs is offline   Reply With Quote
Old 01-29-2006, 10:58 PM   #2 (permalink)
///Matt's Avatar
I have to disclaim any liability for the instructions as I know of people who have messed this up and gotten into a sh*t load of trouble with their electronics. I have done this myself and was successful, but can't guarantee it... That being said http://www.unofficialbmw.com/e36/ele...ce_lights.html
I just used a piece of wire, unlike what this site has you use...
"With the ignition switch at (position two) and the engine not running, grounding pin seven (7) of the diagnostic connector for approximately three (3) seconds will reset the oil service lights. Grounding pin seven (7) for approximately twelve (12) seconds will do an inspection service reset."
Old 01-29-2006, 11:19 PM   #3 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
worked on my e34, with a piece of wire.
unless you ground the wrong pin, there is absolutely nothing you can do wrong ... it might not reset on your first try if you don't time it right, but thats about it.
still, do at your own risk. we cant be responsible.
Old 01-30-2006, 06:23 PM   #4 (permalink)
zoomzoom is an unknown quantity at this point
I don't know where you live, but if the car was serviced under BMW warranty, (oil service) have the dealer drive the 1.5 hour to your house and reset the indicator. If they resist, take it up with BMW customer service. They are normally quick to (re)act. Good luck. ZZ
zoomzoom is offline   Reply With Quote
Old 01-30-2006, 06:49 PM   #5 (permalink)
jeppcharts's Avatar
jeppcharts is an unknown quantity at this point
Send a message via MSN to jeppcharts
I've done this twice with my E39, most recently last week, without any problem. My only suggestion: If you leave the wire in more than about 5 seconds it will reset the inspection counter as well as the oil service timer. Get a friend (or your wife : ) to pull the wire out in time. Otherwise it's a sprint from the cockpit back to the engine to grab it in time.
R. Eric Dawson
'02 X5, '97 528i, '03 Z4
Member BMW CCA
jeppcharts is offline   Reply With Quote
Old 01-30-2006, 09:39 PM   #6 (permalink)
ozarkmark's Avatar
ozarkmark is an unknown quantity at this point
I was too chicken to try the wire grounding thingy - so I bought the Bavauto tool that resets lights and checks/clears code/ inspection what have you...
ozarkmark is offline   Reply With Quote
Old 01-31-2006, 05:43 PM   #7 (permalink)
Fangs's Avatar
Wow, thanks guys. All liability absolved...
'99 323i
'02 540i
Old 01-31-2006, 08:08 PM   #8 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
I don't know how it is on e39, but on e34, you put ignition in pos2, ground it, then you can just turn key back to off when the time u want is there ... i think ...
i dont worry about it, since my car is bound to never see a dealership, i just reset the inspection and everything else every time.
Old 02-01-2006, 01:46 PM   #9 (permalink)
bimmerboy328i's Avatar
bimmerboy328i is an unknown quantity at this point
Send a message via AIM to bimmerboy328i
Hold down the odometer button and turn the key into position 1. You should see test 1 that comes up on the cluster. Wait until reset comes up, let go and then hold until it starts flashing. Once flashing, let go and push again. Done.
- 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 9psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD -
bimmerboy328i is offline   Reply With Quote
Just Got My Baby... What Service To Do??? Guernica 3-Series (E36) 11 04-03-2005 09:07 PM
Should I Get It?! Cellardoor M-Series (M1, M3, M5, M6) 4 02-05-2005 03:19 PM
Inspection I iantosca 3-Series (E36) 5 09-18-2004 12:18 AM
