Well.. all of the sudden, Service Engine Soon light came on in my 01 525i
I went to AutoZone and they plugged the thing in and it came with some fuel leak or soemthing like that. Guy said its probably my gas cap. So I checked it and it was a little loose. Well that was yesterday and the light is still on....
What else could it be? I don't remember exact error, but it was something with vapor, fuel and leak....I should of ask him to show me more details.
Gas caps do trigger the check engine light. If this is the only problem then your light will go off soon. If you're in rush you may disconnect the (-) terminal on your battery for a while then reconnect; this will reset your system providing no other problems present. But for sure it will disappear in 2-3 days if system checks OK
This issue seems to pop up quite regularly doesn't it. It amazes me that the BMW sensor and control system is that sensitive it can detect of loss of fuel tank pressure due to the cap not being on properly.
People often find that replacing the fuel cap is enough to sort this problem out BUT sometimes not (there may be an underlying problem). Follow bills advise - make sure the cap is on properly then disconnect the neg lead from the battery, this resets all the warnings from the computer. Next run the car as normal and if the light comes on again shortly after, you may have bigger problems - now is the time to get your hands on a fault code reader.
