Seat back cable fix - BMW Forum - BimmerWerkz.com
Old 04-26-2010, 03:05 PM   #1 (permalink)
cjscopp's Avatar
Car: 2002 525i and 1995 325i
cjscopp is on a distinguished road
Seat back cable fix
Have a new, much easier way to fix the seatbacks on the E39. The Mrs. told me the seatback was crooked a while back and I researched the shortening of the cable fix. Looked it over and I started the job this morning. Once I had the seats out and the seat back cable removed from the motor, I got to looking at this thing and tried to find another way to effectively lengthen the cable, which is what the method of cutting the cable outer sheath does. It popped into my mind I could cut about 11 mm of the metal end fitting that goes into the motor thus lengthening the cable. I used a tubing cutter to cut the end of the metal off, then I split that piece and put it back on the other side of the collar to make up for the space on the back side between the bracket. It worked really well and I did not have to heat the outer cable sheath, work the metal fitting off and cut the plastic then re-fit it all. Here are some pics I took while I did the job. They are a little blurry but I think you will get the idea.
Seat back cable fix-bmw-seat-repair-004.jpg   Seat back cable fix-bmw-seat-repair-007.jpg   Seat back cable fix-bmw-seat-repair-008.jpg
cjscopp is offline   Reply With Quote
Old 04-26-2010, 05:03 PM   #2 (permalink)
BBenedict's Avatar
Car: 2002 BMW 540i, sport package
BBenedict is on a distinguished road
Your method of effectively lengthening the inner cable is exactly what I did. It's also the method shown in the video.
BBenedict is offline   Reply With Quote
Old 04-26-2010, 05:25 PM   #3 (permalink)
cjscopp's Avatar
Since I did not buy the video I don't know what's in it. Guess I should have thought of it first, than I could be selling instructional videos.
Old 04-28-2010, 02:41 AM   #4 (permalink)
Synesthesia is on a distinguished road
I bought the video too. Best investment, I think. No problems . . . yet . . . keeping my fingers crossed.
Synesthesia is offline   Reply With Quote
Old 10-10-2011, 11:09 PM   #5 (permalink)
Car: 2003 540i M Sport 74K
Huwman is on a distinguished road
I am trying to diagnose the exact same seat twisting problem in my 2003 540i with the sport seats. I have the passenger seat out but I don't see any sign externally that the cable is not engaging the motor or gearbox. Should I be able to see it if it is not engaging? Second, how do I know if it's the motor interface of the rear/gearbox interface that's FUBAR'd?
Huwman is offline   Reply With Quote
Old 10-11-2011, 11:15 AM   #6 (permalink)
cjscopp's Avatar
You will not be able to see anything from the outside. You can check the operation of the gearboxes by removing the cable ends at the electric motor end and manually operating them with an electric drill. This also allows you to balance each side back to equal. If the manual cable operation works and the seat back moves correctly, apply this cable modification as described above to put more of the metal cable into the electric motor and you will be good.
Old 10-12-2011, 12:01 AM   #7 (permalink)
Hey thanks much!
By the way, should I do both sides of the cable/motor while I'm in, just to head off any future problems?
Old 10-12-2011, 11:12 AM   #8 (permalink)
cjscopp's Avatar
Glad to help. I suggest you do both cables while you are there. You will see the two cables come out of either end of the same motor and go to each side of the seat. Good luck.
Al
Old 10-12-2011, 11:14 AM   #9 (permalink)
cjscopp's Avatar
Yes, you should do both sides while you are there. As soon as you don't the other side will malfunction. Good luck
Old 10-25-2011, 06:54 PM   #10 (permalink)
raybmw is on a distinguished road
seat cables
i have the same problem,where do i get the video,thanks guys.
raybmw is offline   Reply With Quote
Old 11-05-2011, 07:10 AM   #11 (permalink)
Thx again-did both sides of the motor, reinstalled and it's good as new. What a PIA though.
How to fix driver side seat plastic mold from falling off! prmoorman1 5-Series (E12,E28, E34, E39, E60) 0 08-13-2008 10:35 AM
How to remove leather seat back and bottom from seat frame mitch.smith 3-Series (E36) 0 07-09-2007 10:19 AM
Seat Gone BAck and Cant GO BAck UP =( chexicanone 5-Series (E12,E28, E34, E39, E60) 10 11-18-2005 09:26 AM
Fix For Lower Part Of The Seat? streetdreams 3-Series (E36) 3 11-25-2004 11:12 AM
