Rotors on my 528E - BMW Forum - BimmerWerkz.com
Old 01-16-2004, 03:50 PM   #1 (permalink)
M5power is an unknown quantity at this point
the screw holding on my rotor for my front left of my car. well its stripped, badly. does this screw absoultely have to be in there or will the wheel be able to hold it in good enough? b/c otherwise im going to have to take a drill through the screw to get it out. then get it tapped ghead
<img src='http://www.tehseen.net/david.jpg' border='0' alt='user posted image' />
The b0x that r0x
M5power is offline   Reply With Quote
Old 01-16-2004, 04:33 PM   #2 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
when i do brakes if theres a screw then i put it back but its only real purpose is to keep the rotor center when your putting the caliper back on. a lil screw cant keep a rotor on a car not possible. just throw it back together and lug it up nice.
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 01-16-2004, 05:40 PM   #3 (permalink)
TECH's Avatar
Is it just the head that is stripped? If so, you can take a torx bit that fits tight into the hole, actually a tad bigger than the hole, and hammer it into the head. This should bite well enough to back it out normally.
All the screw is for is to hold the rotor flush to the hub, so you can get the wheel on easily, without the rotor tipping off the hub, and it also keeps the lug holes aligned-the hub centers the rotor.
Old 01-17-2004, 04:44 PM   #4 (permalink)
alrite, sweet thanks alot for the tips! im just trying to get that stupid screw out so i can get my cross drilled rotors in, and with the advice i'll be able to pull it off.
The b0x that r0x
Brake rotors a must change?? Z0Sicks 3-Series (E46, E90) 3 11-06-2005 01:23 PM
88 528e Auto Trans Electron 5-Series (E12,E28, E34, E39, E60) 11 03-21-2005 10:24 PM
Oem Brakes And Rotors Or Aftermarket? mp5 3-Series (E46, E90) 2 11-13-2004 05:56 PM
Brake and Rotors roguesniper1 3-Series (E36) 11 05-14-2004 06:45 PM
HELP: Replace the Rotors Fangs 3-Series (E46, E90) 4 12-10-2003 08:31 AM
