That's kind of suprising that its not prewired, I'm not sure I've run across one that isnt. Anyways, I am pretty sure they are plug and play. You will have to have the cd changer cable that goes from the radio to the rear. It should be the only DIN plug behind the radio left open.
to werkz BTW...
Thanks for your answer.
Unfortunately I confirm my car is not pre-wired ("Eletta" italian version). Neither there are cables connected behind the radio, nor there are cables behind in the cd-changer box.
Of course, it would be very usefull to have instructions about how to pass cables under the carpet (and so on) from the rear box up to the radio.
The toughest part will be getting from the radio to the passenger side kickpanel. I suggest the passenger side becasue the glovebox can be removed fairly easy. basically the passenger side, pull the sill plates in the door jambs from front to rear. just tuck the cable under the carpet, making sure to clear any place where a screw might go in. I am assuming the radio is cd changer compatible. If it is, the cord will just plug in, plug in the other end into the change and the radio should recognize it with the CD button.
on CD changer you will have 3 connections.
A) 3-pin connector requires 12v+, i-bus signal, ground
B) DSp coaxial connector (only used with DSP)
C) 6-pin audio connector- carries individual speaker wire inputs
you will need to run all these wires from radio in front of car to the back of the car where you are installing the CD-Changer.
As far as the connector housings.. it may easiest to go to a salvage yard and get them... finding part #s in BMW's Parts catalog for connectors is miserable.
As far as wiring diagrams and pinouts try this site or the Bentley manual....
I have e39 528, 1996, with casette business radio RDS (no DSP), there is no wiring to the back of trunk, so i need cable from radio + connector for power supply?
power supply cable also needs to be wired from radio??? I thought that i will plug it at the back. Can someone give detailed info, please
