| If you do non-scheduled oil changes you should not reset the light as it is tied into the inspection settings also. You can jumper between a pin in the 20 pin service interface port and ground to reset the light. There is a diagram of how to do this in one of the FAQ sections.
Ben
__________________ "It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife. |
