Removing outer Door Pillars on a 1990 535i E34 - BMW Forum - BimmerWerkz.com
Old 02-21-2011, 01:56 AM   #1 (permalink)
Playr4free's Avatar
Car: '90 535i
Playr4free is on a distinguished road
Post Removing outer Door Pillars on a 1990 535i E34
So I finally got tired of my damaged door pillar and decided to post up a few pictures since I was bored and couldn't find the instructions on how to remove the pillars on the doors online. Hope this comes useful to someone!
MAKE SURE YOUR WINDOW IS IN THE DOWN POSITION!
Might be a good idea to use latex gloves to shield you against the EVIL DOOR TAR aaaand if you choose not too and get all messy use a cloth with some acetone to scrub it right off and some dish washing soap to get any remaining traces off!
1. First off you need to remove the door panel. Here's a link that shows how if you're not used to doing so already.
Door removal : BMW E34 Website
2. After you've tackled that you'll need to remove the plastic covering that runs along the top portion of the door all the way down to where the weather stripping ends. While standing outside the door pull the vertical part of the plastic towards the inner part of the door and down. Be careful not to pull too hard or you'll crack the plastic at the top corner. I also ran a screwdriver along the inner side to help me a bit...just be patient with it and dont force it
3. Ok almost done. Again while on the outside of the door pull back on the weatherstrip that runs along the pillar there are 3 phillips head screws in there about 6 inches apart. Remove and save in a safe location...like errm your pocket.
4. Ok now for the awesome part! Grab hold of the pillar and gently pull away from the frame about 1/2 inch or so remove the weatherstrip running through it and tilt the pillar back about 1 inch and then up. You might have to wiggle it out a little but other than that it should slide ride out.
Ok now to work! Im still in the process of painting since ive decided ill be removing the other 3 pillars and repainting them as well. Ill update this if i find anything interesting later on this week...but heres the current progress...ps dont judge the magical jb weld im a broke college student!
Playr4free is offline   Reply With Quote
Old 02-21-2011, 09:27 AM   #2 (permalink)
Very nice!
Old 11-15-2011, 08:36 AM   #3 (permalink)
J and L Auto Glass is on a distinguished road
Hey man, this is a great post. I am looking for one on a 2007 335i front left, for my customer's, door panel removal...do you know of one?
Thanks
J and L Auto Glass is offline   Reply With Quote
Old 11-15-2011, 01:14 PM   #4 (permalink)
Playr4free's Avatar
Car: '90 535i
Merry X-mas!!I found two links ....
BMW E92 Door Panel Removal BY e90post
DIY-Door panel and outside mirror... - BMW 3-Series (E90 E92) Forum - E90Post.com
Old 11-15-2011, 08:44 PM   #5 (permalink)
LOL - Thank you...same right back "Merry Christmas"
Ron Jackson - J and L Auto Glass
Owner & Tech - 615-497-6369
Old 11-17-2011, 12:16 PM   #6 (permalink)
arnoldreg is on a distinguished road
Thanks for describing the process. I can try this on my bimmer now.
BMW Car Parts
arnoldreg is offline   Reply With Quote
Old 11-17-2011, 01:15 PM   #7 (permalink)
Playr4free's Avatar
Car: '90 535i
nice hopefully ill have some time later so i can post the instructions on how to remove the small little metal strip on the rear doors (you know the ones that fade and start to rust on all cars)
Replacing outer door gaskets E36 smart1 3-Series (E36) 6 11-13-2008 08:31 PM
E34 1990 535i stevet99uk 5-Series (E12,E28, E34, E39, E60) 1 06-18-2005 02:30 AM
Carbon Fiber Door Pillars jbcritch 3-Series (E46, E90) 1 12-07-2004 09:13 PM
1990 535i Makailaw 5-Series (E12,E28, E34, E39, E60) 5 11-24-2004 03:39 PM
1990 535i and looking what to do next... Maz 5-Series (E12,E28, E34, E39, E60) 0 10-03-2003 12:04 AM
