rear power windows fail to raise - BMW Forum - BimmerWerkz.com
post #1 of 19 (permalink) Old 05-17-2008, 10:17 PM Thread Starter
Dlan is on a distinguished road
I have a '98 5401.
Last year my right rear window failed to rasie after I had lowered it. So I manually pulled it up. It will still go down via the power button but will not rise. Since no one hardly ever sits back there I wedged it shut.
Yesterday I ran my left rear window down and it failed to come back up. I can manually push this windows up or down, or lower them with power button, but not rasie them without manual manipulation.
Can anyone tell me what going on with these windows, and can I fix them myself
Dlan is offline
post #2 of 19 (permalink) Old 05-18-2008, 12:15 AM
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold
relube them and clean out you switches.....
1992 318i Coupe parts car
I am Captain Obvious
AlpineSixAndSeven is offline
post #3 of 19 (permalink) Old 05-18-2008, 09:32 PM
da_administrator
da_bull's Avatar
da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute
If you are able to pull your switches out, swap the rear left and right for each other, see if the problem switches sides. That'll let you know if its the switch or a motor.
da_bull is offline
post #4 of 19 (permalink) Old 05-19-2008, 10:42 AM
BALKAN's Avatar
BALKAN is on a distinguished road
I have the same problem right now with drives side rear window. I was told it is the regulator and plan on replacing it. Ill post details and if it worked.
BALKAN is offline
post #5 of 19 (permalink) Old 05-19-2008, 11:36 AM Thread Starter
Thanks for the reply, but both sides are acting the same now. I can hear the motors running, but windows fail to rise.
Dlan is offline
post #6 of 19 (permalink) Old 05-19-2008, 11:37 AM Thread Starter
Thanks, I'll keep a eye out for your report
Dlan is offline
post #7 of 19 (permalink) Old 05-19-2008, 09:46 PM
da_administrator
da_bull's Avatar
It seems I remember reading somewhere about these cars' windows jumping off track or something like that. You may have to remove the door panel and see what's going on. I found this on the E34 but may be similar on yours: BMW E34 Website
da_bull is offline
post #8 of 19 (permalink) Old 05-29-2008, 11:26 PM Thread Starter
appreciated
Thanks for the link, I will give it a try.
Dlan is offline
post #9 of 19 (permalink) Old 05-30-2008, 02:00 AM
Moderator
Dirty_Tool's Avatar
Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute
sounds liek a couple failed window regulators. theyre usually not repairable, theyre totally different than e34. Prob going to just have to replace them.
DT
Dirty_Tool is offline
post #10 of 19 (permalink) Old 05-30-2008, 03:54 PM Thread Starter
Unhappy
Thanks for the reply, even though that' what I'm afraid for. Are they costly?
Dlan is offline
post #11 of 19 (permalink) Old 05-30-2008, 04:24 PM
winters97E39's Avatar
winters97E39 is a jewel in the rough winters97E39 is a jewel in the rough winters97E39 is a jewel in the rough
regulators for E39 are like $125 each, I had to replace one when I bought mine a couple years ago. Same problem, would roll down but not up. If you pull the inside door panel apart you may be able to determine the problem just by visual inspection.
Jason / 1997 528i
winters97E39 is offline
post #12 of 19 (permalink) Old 05-31-2008, 12:14 PM Thread Starter
Thanks for the info. Since both rears have now failed I was wondering if this is characteristic of these cars, and should I start to worry about the front windows failing!
Dlan is offline
post #13 of 19 (permalink) Old 05-31-2008, 11:21 PM
darkhorse737's Avatar
Quoted: 2 Post(s)
the weakness in window regulators(in practiaclly all cars) is the plastic runner that runs through the window regulators rails while your window moves up and down. They're made of plastic, and made to rub against metal rails.... (for the shooosh of operation) but they do break into pieces over time. on some models, u can replace just the plastic pieces, and on some models, they are riveted in place.
Depending on how creative u are(as these plastic pieces are available on eBay) u can choose to just replace the plastic OR..... "dread", bear the cost of replacing the whole regulator.
i.e. on BMW, Benz & Ford.. the regulator costs an average $200, but u can buy the plastic runners on eBay for $4.-(plus shipping) knock out/grind out the rivets from the old regulator, replace and then rivet the new one's.... and then re-install.
darkhorse737 is offline
post #14 of 19 (permalink) Old 06-02-2008, 01:16 PM Thread Starter
Thanks Darkhorse. I haven't worked up the courage to dissasemble the rear doors but will tackle it when I come back from vacation next week
Dlan is offline
post #15 of 19 (permalink) Old 06-05-2008, 01:29 AM
pinnaclebass is on a distinguished road
Send a message via AIM to pinnaclebass Send a message via Yahoo to pinnaclebass
just replace regulator or motor. and be done with it. best remedy. once u get the door panel off anyway it can get to be a hassle to work in those doors and windows. talking from experience.
pinnaclebass is offline
power windows driftin325s 3-Series (E21, E30) 3 12-13-2005 08:33 PM
Power Windows SueDan 3-Series (E36) 7 09-05-2005 05:28 AM
Power Windows Bunny Capricorn 3-Series (E21, E30) 4 08-15-2005 12:47 PM
Power Windows ccfuller 3-Series (E21, E30) 1 02-25-2005 08:40 PM
Power Windows studio945 3-Series (E46, E90) 4 01-18-2004 07:03 PM
