Rear Ball Joint Replacement - BMW Forum - BimmerWerkz.com
Old 04-04-2005, 11:43 AM   #1 (permalink)
Eric S.'s Avatar
Eric S. is on a distinguished road
A BMW master tech recently examined my car (a freebie event sponsored by the local chapter of the BMW CCA). He noted that my left rear ball joint was worn and needed replacement. He said the right rear was OK and that I only needed to replace the one side - unnecessary to replace in pairs.
My 1999 540/6 is at 110K miles. I'm figuring I ought to just replace both rear ball joints; the ball joint is only about $30 each at the dealer.
Are these babies tough to replace for Joe Average wrench-turner? Any special tools required? Alignment required afterward? Should I do both sides?
PS - After seeing how easy it would be to do and how cheap it was, I ordered my M5 rear sway bar and will be picking it up later this week....
<span style='colorurple'>Eric S.</span>
2006 Honda Odyssey EXL-RES
Eric S. is offline   Reply With Quote
Old 04-04-2005, 11:50 AM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
Eric,
This job requires an expensive ($150) tool and is kind of a bear to do. An alignment is required aterwards. I personally would recommend doing them in pairs because if you spend a couple hundred bucks on an alignment and the other ball joint goes bad in a few months you're gonna have to replace it then align it again, so you will pay for an alignment twice. I'd say get that rear sway bar on yourself then pay the pro's to do the rear ball joints and alignment.
Good Luck,
DT
DT
Changed Out My Rear Ball Joints Today Eric S. 5-Series (E12,E28, E34, E39, E60) 1 01-03-2009 12:07 PM
Ball Joint Replacement irish 3-Series (E21, E30) 5 05-21-2005 12:47 AM
E36 Suspension Work, Want To Upgrade Suspension? victorgallas Product Reviews 8 02-08-2005 08:21 AM
Control Arm Ball Joint Renewal Foley 3-Series (E21, E30) 9 09-27-2004 07:33 PM
Rear speaker replacement for e46 GnarlyCow Audio and Electronics 1 06-01-2004 08:44 AM
