have a rattle from rear brakes (or somewhere near there) when driving even on slightly bumpy roads. could brake pads rattle around in calipers? any ideas,
this drives me nuts.
Bigron as usual to this forum and I tell you- anything/everything can rattle- but prior to go after brake pads I'll check rear shocks/ any rubber bushing in the back/ loose parts i.e muffler then take it from there....good luck
Note: Usually you can eliminate many possibilities if you can REPRODUCE the rattle at will....
I have had the same problem for months and today I finally found it !!!! It was the rear brake pads (on the piston side of the caliper) Whomever installed the rear brakes didnt put any grease or anything to keep them quiet. So whenever driving they would clank off the rotor. I found some great rubber invention (allmost like a liquid gasket material) at an autopparts store, it lightly adhears the pad to the piston and rubberizes to prevent vibration. Problem solved for $2.00
Bigron I hopes this helps, because after driving around for two months in a beautiful bimmer that sounds like its falling apart, I know how imbarassing it can be.
Thanks for your help Billb...once again....its appreciated
Originally posted by billB@May 15 2005, 09:11 PM Bigron as usual* * * to this forum and I tell you anything/everything can rattle...but prior to go after brake pads I'll check rear shocks/ any rubber bushing in the back/ loose parts i.e muffler then take it from there....good luck
and just a quick note here on what u have said: ""............Whomever installed the rear brakes didnt put any grease or anything to keep them quiet."" NO GREASE ON ANY BRAKE PADS!!
What they usually use is special type of GLUE to keep the BACK of the brake pads glued to the piston.....this eliminates the possibility of pads touching the rotors... just my 2 cents...good luck gentlemen.
