Radiator Help - BMW Forum - BimmerWerkz.com
Old 07-05-2004, 09:40 PM   #1 (permalink)
dberger's Avatar
dberger is an unknown quantity at this point
I just bought a 1998 BMW 528i and had it for 45 minutes when the radiator blew. The upper hose on the right came off and with it was the threaded plastic piece that is part of the radiator. I need some advice on getting it fixed and if there could be underlying problems beside this. Which New radiator, Nissens or Behr? and will garages install a part that I were to buy do you think?
thanks,
dberger
dberger is offline   Reply With Quote
Old 07-06-2004, 10:27 PM   #2 (permalink)
njtech is an unknown quantity at this point
dberger ,
There could be a problem with the waterpump, very common that the plastic impeller overheats and separates from the shaft cauing the car to overheat and breaking the upper part of the radiator. As far as a shop installing a part supplied by you, most places shouldn't have a problem if you provide them with a quality part. You probably won't get any warranty aside from the installation. I would use the Behr. HTH
Steve
njtech is offline   Reply With Quote
Old 07-06-2004, 10:48 PM   #3 (permalink)
nshape8 is an unknown quantity at this point
eBay...
nshape8 is offline   Reply With Quote
Old 07-07-2004, 01:25 AM   #4 (permalink)
silverlea is an unknown quantity at this point
Bad luck..............Have a look at the water pump..........never a strong point on the cars we drive !
If the radiator is the problem it should be easily fixed,or if even worse than that you could have it re-cored.A re-cored one is usually about half the price of a new one. Myself I would go for a brand new one from BMW dealer.If you do that you'll know exactly where you are.Change all the hoses while you are on the job also.
Good luck.
SILVERLEA.
silverlea is offline   Reply With Quote
Old 07-07-2004, 08:36 AM   #5 (permalink)
dberger's Avatar
thanks everyone, I just replaced the Rad with a Nissen and runs ok now.
