Radiator Fan Is Always On - BMW Forum - BimmerWerkz.com
Old 11-16-2006, 03:24 PM   #1 (permalink)
BMW5S5RI5S is on a distinguished road
I Have A 1998 528i And The Fan Is Always On And Its Annoying Does Anyone Know Wat Can Be The Problem?
BMW5S5RI5S is offline   Reply With Quote
Old 11-16-2006, 04:12 PM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Yea.... a temp sensor... or the fan relay is bad... take it to a shop if you are unable to find the problem...
If you have the bentely manual... there are procedures to test such things.
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 11-16-2006, 09:38 PM   #3 (permalink)
cnn
cnn is on a distinguished road
This should help
http://www.bmwtips.com/tipsntricks/auxfan/auxfan.htm
cn
cnn is offline   Reply With Quote
Old 12-02-2006, 08:58 PM   #4 (permalink)
aktansrt is on a distinguished road
It is most likely your fan resistor, final stage. If it keeps running intermittently even after you turn the engine off, drain your battery, and seems to have a mind of its own, look for a new Final Stage Unit (i.e. blower motor resistor).
It should be about $75 online. Check autopartswarehouse.com or bmw-parts-direct.com
aktansrt is offline   Reply With Quote
Old 12-05-2006, 01:22 PM   #5 (permalink)
ipodwheels is on a distinguished road
Hope this helps
Try anyone of the following:
Look up the temperature sensor if you have one.
Check the fan control for any fault
Check your resistor block for the blower motor.
You may need to change any of the following or have it fixed. A firend had the same problem once with his Mercury. It ended up with him replacing his switch.
Check Auto Parts Place or Howstuffworks for more info on parts and replacements.
ipodwheels is offline   Reply With Quote
