Quick Question About Mpg - BMW Forum - BimmerWerkz.com
Old 03-08-2005, 10:10 PM   #1 (permalink)
da_administrator
da_bull's Avatar
It seems as if it happened when I took my clock/mpg/everything else display out to replace the little pain-in-the-butt-to-replace bulbs. My mpg works fine, but the range shows like 445+ when I fill up and when the "low-gas" indicator light comes on it still thinks I have 300-350 miles left when I hit "Range". This thing used to be fairly accurate, but not now. I also swear there used to be an instant setting somewhere that would show real-time mpg, like letting off the gas going downhill would peg it at 99+ or whatever the highest one was. Anyone familiar with this. Thanks in advance....
Old 03-09-2005, 07:21 AM   #2 (permalink)
machinehead's Avatar
machinehead is an unknown quantity at this point
Send a message via MSN to machinehead Send a message via Yahoo to machinehead
I had a similar thing with a 2nd hand OBC for my E34. Whe it was cold, say for the first 10 miles, it would read ok, then the reading would creep up and finally reads 99.9 mpg, range 400+ miles. It (the OBC) seems to loose the sense of the fuel being used (from the fuel injection computer) so when it registers only a small amount of fuel over large number of miles the calculation of MPG comes up with the max. displayable value of 99.9
I hoped it was just a bad connection on the multi-plug (worth a check) but no such luck so I’ve had to bin the unit and buy another (the joys of second hand stuff) the replacement works just fine and reads about 25mpg (which is what I reckoned before I got the OBC )
If anyone has an answer I’ll try and fix the other one and give it to my brother as his doesn’t have one fitted to his cars either!
Hope your problem is less drastic but thought I'd share my experience.
<span style='color:blue'><span style='font-size:9pt;line-height:100%'><span style='font-family:Arial'>because life's too short not to..........</span></span></span>
machinehead is offline   Reply With Quote
Old 03-09-2005, 04:16 PM   #3 (permalink)
da_administrator
da_bull's Avatar
The actual mpg I get is displayed correctly (18-20). Its just every time I have to fill up, it shows I still have 300 miles left before empty. When I fill up it just goes to a higher number (445+ or something to that effect)
Quick question about clear corners comncense 3-Series (E46, E90) 1 10-22-2005 03:22 PM
quick question? stracer 3-Series (E36) 2 10-07-2005 04:54 AM
Quick Question About Two Different DDE's... Red93B3M2W5i 3-Series (E36) 4 10-07-2005 12:19 AM
one quick question here! JDM 3-Series (E46, E90) 16 02-06-2004 05:18 PM
Quick question about shocks and struts. CyPHER 3-Series (E36) 5 12-14-2003 04:12 PM
