Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 09-29-2007, 06:00 PM   #1 (permalink)
jnstrcklnd's Avatar
Photos: 0
jnstrcklnd is just really nicejnstrcklnd is just really nicejnstrcklnd is just really nicejnstrcklnd is just really nice
Exclamation Quick Question.
Hey guys, been awhile. I just have a quick question. I might be buying a 94 530i, 3.0L V8 and 5 speed. Only has 131k miles. The owner says he put in a new clutch and had the flywheel machined at the same time. He got it all ogether and he said there is a vibration coming from that area now. But he said it might go away when it breaks in. What do you guys think? Worst case it needs a new flywheel or????
jnstrcklnd is offline   Reply With Quote
Old 09-29-2007, 06:33 PM   #2 (permalink)
To the left ...
Torque's Avatar
Car: '90 535im
Photos: 0
Send a message via AIM to Torque Send a message via MSN to Torque
Depends on what sort of vibration. When releasing the clutch or when clutch is already hooked up and accelerating?
Old 09-30-2007, 01:01 AM   #3 (permalink)
jnstrcklnd's Avatar
Photos: 0
I want to say whjen hooked up and accelarating, but I dont really know. Im going down tomorrow morning to check her out. Whats the worst case? Anything else I should look out for? Thanks Torque!!!
Here is the original posting for the car. It dosnt mention the vibration though... 1994 BMW 530i V-8 5 speed
Old 09-30-2007, 01:25 AM   #4 (permalink)
To the left ...
Torque's Avatar
Car: '90 535im
Photos: 0
I'm worried about the "runs rough at times" more than the vibration.
It may still be the nikasil engine ... look into that; check the casting numbers on the block. You do not want a rough running v8 ... that can only mean trouble. Read this and look or have a mechanic check the numbers BMW M60 - Wikipedia, the free encyclopedia
edit: If it is a newer, Alusil block, have a leakdown and compression test performed ... something doesn't add up here: '94 530 for 2000. I paid more for a '90 535.
As for the vibration: if the clutch is already hooked up, it's more than likely something to do with the driveshaft. Possibly:
- Guibo/flex disk gone or installed backwards/out of alignment.
- Worn carrier bearing
- Incorrectly adjusted preload on the carrier bearing.
Hope that helps.
Old 09-30-2007, 07:18 PM   #5 (permalink)
jnstrcklnd's Avatar
Photos: 0
Well, I didnt get a chance to get down there and look at it today. But hopefully tomorrow. Is there anything specific that I should ask the dude? Im not going to be able to have extensive testing done to it like the leak down or compression.
Old 10-01-2007, 09:58 AM   #6 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Photos: 1
It can also be the drive shaft or flex disk among other things!
How fast are you going when it shakes? 20mph?30 or 55-60?
LOS
vB code is On
quick question trinidad 325i 3-Series (E36) 7 02-20-2007 08:42 AM
quick ac question??????? silenti 3-Series (E36) 4 04-15-2006 10:54 PM
a quick question 325is94 3-Series (E36) 2 02-10-2006 11:54 PM
Quick question about clear corners comncense 3-Series (E46, E90) 1 10-22-2005 04:22 PM
Quick Question About Two Different DDE's... Red93B3M2W5i 3-Series (E36) 4 10-07-2005 01:19 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
