Question On About The Clutch - BMW Forum - BimmerWerkz.com
Old 02-10-2005, 12:02 PM   #1 (permalink)
Scotty Dangles is an unknown quantity at this point
Good Day,
I just have a quick question regarding clutch wear. I have a 94 530i with a 5 speed manual transmission with 183,000KM. This morning I noticed a significant difference in the stiffness of the clutch peddle.(could be from the cold weather)
Since I've owned the car (2 months), I have noticed a slight resistance when pressing down on the clutch. Since this morning I have noticed that the resistance only occurs about midway rather then right at the beginning when pressing on the clutch peddle. Shifting is still fine, its just the lack of resistance has made me make some adjustments to my shifting.
Let me know if this is a sign of wear or something I should worry about.
Cheers
Scott
Scotty Dangles is offline   Reply With Quote
Old 02-11-2005, 12:23 PM   #2 (permalink)
drifts14x's Avatar
drifts14x is an unknown quantity at this point
Does it feel like it's slipping? When you punch the gas in a gear, does the tach go up before you feel power going to the ground, because if that's the case, you are going to have to replace your clutch soon. Also, Can you smell fluid burning when you step on it, because that is a sure sign too.
My Cars:
*SOLD*
1992 Nissan 240SX
Full Suspension Work(Shocks,Springs, Subframe Spacers, JDM Sway Bars, etc)
Silvia Headlight Conversion
Watanabe RS-8 Wheels
198k and still going strong
See it at <a href='http://www.cardomain.com/id/s13driftx' target='_blank'>My Cardomain Page</a>
*Still Rockin*
1992 E34 BMW 525i Wagon
AC Schnitzer Performance Chip
172k Miles
<img src='http://www.bmw-forums.com/forum/index.php?act=Attach&amp;type=post&amp;id=19233.jp g' border='0' alt='user posted image' />
Rockin the High Mileage Performance
drifts14x is offline   Reply With Quote
Old 02-11-2005, 02:47 PM   #3 (permalink)
No, actually there is no slip at all. There is just a lot free play with the peddle. Also the peddle does not want to come back up on its own. I do not smell any burning when I punch it.
This morning after I took it for a prolonged ride hopeing it would correct itself...which it did somewhat...I had much more free play with the peddle andeven with the clutch pressed all the way the car would move forward. I also could not shift into any other gears.
Could this be a fluid delivery problem??
Thanks
Old 02-12-2005, 08:09 AM   #4 (permalink)
njtech is an unknown quantity at this point
possible clutch master problem,check your floor mat for any signs of fluid leak. if not, it sounds like you are going to need a clutch. email if you have any questions.
Steve
njtech is offline   Reply With Quote
Old 02-14-2005, 08:19 PM   #5 (permalink)
Alright I have confirmed its a leak of some sort, I'm guessing the master cylinder. Does anyone know if I could get a rebuilt master cylinder? Any recommendations on where to find one for a good price?
Cheers
Scott
Old 02-15-2005, 11:26 AM   #6 (permalink)
Cheers
Scott
[snapback]292015[/snapback]
Scott,
where are you located I can get you the clutch master(new not rebuilt) for about $105 +shipping. let me know.
Steve
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
Buying Used M3 - Clutch question gollywog M-Series (M1, M3, M5, M6) 9 05-14-2004 07:29 PM
E36 M3 UUC Flywheel Wrong Clutch Becherert 3-Series (E36) 1 03-09-2004 01:39 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
Clutch question Rand 3-Series (E21, E30) 2 09-27-2003 03:07 PM
