Power steering pump noise - BMW Forum - BimmerWerkz.com
Old 01-02-2004, 09:23 PM   #1 (permalink)
bmwm6 is an unknown quantity at this point
I have a 1987 535i with a severe noise in the power steering pump. I replaced the pump, but the noise is worse....any ideas... Please email to rich@pacsport.com as we are desparate for answers.
Rich
bmwm6 is offline   Reply With Quote
Old 01-02-2004, 09:52 PM   #2 (permalink)
Did you change the filter in the reservoir?
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
Old 01-02-2004, 10:50 PM   #3 (permalink)
I also have this noise in my 1990- theres a filter in the reservoir? the reservoir seems too small to contain a filter...
About where is it located?
thanks
Old 01-03-2004, 04:41 PM   #4 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
you guys sure your belt not slipping?
how bout the high pressure line is it leaking onto the craddle of the car and not hitting the ground?
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 01-03-2004, 08:16 PM   #5 (permalink)
the hose coming from my reservoir down is leaking, and has created a below it.
but im am pretty sure the belt isnt slipping (although thats how it sounds) because the belts are new and they look like they have no wear on them.. the tension also seems to be correct.
Could that hose be the cause of the noise? also the fluid is old and smells burned, would changing that help any?
thanks.
Old 01-03-2004, 08:51 PM   #6 (permalink)
CBA
CBA's Avatar
if its hydrualic properties are in sync then it should be fine..
but if that hose is leaking youll get a noise.. no fluid or lack therof would mean your running the pump dry.. and it takes insane amounts of psi to turn that rack.. somethin like 1500-3500 psi..
-Founder
Power Steering pump repair scottm3 M-Series (M1, M3, M5, M6) 4 10-03-2005 12:40 PM
Power Steering Noise supark 3-Series (E36) 4 11-02-2004 08:45 PM
Link Play In Power Steering BMWhatever 5-Series (E12,E28, E34, E39, E60) 0 10-11-2004 12:23 PM
Water Pump And Power Steering Pulley Torque Spec's silver328is 3-Series (E36) 5 10-07-2004 03:39 PM
Power Steering Pump Tadao 3-Series (E21, E30) 1 01-13-2004 01:57 AM
