Pending problems with my 530, 2002 - BMW Forum - BimmerWerkz.com
Old 03-16-2009, 01:26 PM   #1 (permalink)
Car: 530i-2002 & E280-2007
rashid is on a distinguished road
Solved number of problems recently on my 530-2002 but the following problems are still pending & I am looking for further help on them.
1. I am using Mobil 2000 engine Oil that lasts for 20,000 KM, but every time I change, I found the Oil level less by around one Liter .. is that normal or not?
2. There is a noise like a litle Bird in the engine compartment!! changed all belts but the noise is still there!! I failed to know the reason for that noise.
Any help on the above two issues?
rashid is offline   Reply With Quote
Old 03-16-2009, 10:54 PM   #2 (permalink)
Car: 2002 530i Sports/Prem Pkg
longrob is on a distinguished road
Bird Chirping Sound
I got that same bird chirping sound over behind the passenger side dash! It doesn't stop when I shut off the climate control system fan; can't find it- sometimes drives me crazy. The car has no rattles or squeaks, but does chirp, but not all the time, eeeeck.
-Rob
longrob is offline   Reply With Quote
Old 03-18-2009, 02:25 PM   #3 (permalink)
Car: E39 & E46
16valex is on a distinguished road
Changing oil at 20KM interval is crazy, you should change your oil more often, oil is cheaper than engine. But anyways, the amount of oil lost you have is perfectly normal. Please change your oil at 7.5KM not 20KM.
As for the chirping sound. does the chirping go away if the engine is OFF?
16valex is offline   Reply With Quote
Old 03-18-2009, 03:28 PM   #4 (permalink)
well yes, it does for me, so I guess it is not a real bird
Rob
Old 03-19-2009, 12:02 AM   #5 (permalink)
1. The BMW dealer was changing oil for my BMW every 20K & I am now using the same oil for the same milage, which is also as per the oil change intervals shown by the system!
2. yes, the chirping go away if the engine is OFF!
Old 03-19-2009, 12:08 AM   #6 (permalink)
The engine oil should be changed more often. Seriously.
Old 03-19-2009, 05:15 AM   #7 (permalink)
Noted with thanks ...
Old 03-19-2009, 09:49 PM   #8 (permalink)
Any feedback on the chirping??
Old 03-21-2009, 04:59 AM   #9 (permalink)
Dudesky_E36's Avatar
Car: Anthracite e39 530iA
Dudesky_E36 is an unknown quantity at this point
Send a message via AIM to Dudesky_E36
Is the sound coming from the front of the engine near the belts? I had a chirping sound and it turned out to be the water pump.
Dudesky_E36 is offline   Reply With Quote
Old 03-21-2009, 05:47 AM   #10 (permalink)
I feel the sound only when I am driving & it is shady (not all the time). Can you decribe your problem & how you solve it?
Old 03-21-2009, 11:44 AM   #11 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
does it sound like it could possibly be coming from the wheels? possibly a wheel bearing...
Old 03-21-2009, 03:50 PM   #12 (permalink)
Hewi's Avatar
Car: 2000/BMW/530iM
Hewi is on a distinguished road
1: The oil consumtion is perfectly normal , Most M54 motor consumes mutch more oil than yours , the oil that you use is no longlife oil som also I rekommend that you change a little more often(round 15000km). The oil you should use is a Bmw LL01 approved oil in your car and with that you can change when your service meter tells you to change.
2: It maybe a worn beltwheel or bearing in the alternator , its hard to say.
BMW 530iM-01 Immola Rot
Hewi is offline   Reply With Quote
Old 03-22-2009, 02:00 AM   #13 (permalink)
thanks ..
Old 03-22-2009, 10:21 AM   #14 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Don't wait for the service indicator to tell you to change your oil! Change your oil with synthetic every 6000 mi or 10000 km, or at least every six months regardless of miles/km.
The service indicator intervals are designed to make the car last through the warranty period. To give your engine a long life, you ought to take better care of it than BMW suggests.
Turkey Fleet Bond Holder
Old 03-22-2009, 12:00 PM   #15 (permalink)
Hewi's Avatar
Car: 2000/BMW/530iM
Why change an oil that there is nothing wrong with? If your oil only stay good for 6 months or 10000km you have bought something very cheap! Think about the enviroment! I have never heard about a modern car that have failed because of the owner have changed the oil by the service plan , have you?
Washer fluid leaking - E39, 530-2002 rashid 5-Series (E12,E28, E34, E39, E60) 10 12-08-2009 07:24 PM
Instrument panel withe different scales - e39, 530-2002 rashid 5-Series (E12,E28, E34, E39, E60) 12 05-18-2009 02:40 AM
Traction control light - 2002 530 i madarkar 5-Series (E12,E28, E34, E39, E60) 0 07-06-2008 12:31 PM
Will 245/45/17 Tires Fit My 2002 530 Sport? ErikB 5-Series (E12,E28, E34, E39, E60) 4 12-10-2004 01:15 PM
HELP: 2001/2002 530 HuliganRS 5-Series (E12,E28, E34, E39, E60) 1 05-12-2004 10:18 AM
