Over Cooling? - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 12-01-2004, 02:15 AM Thread Starter
liquidtiger720 is an unknown quantity at this point
Send a message via AIM to liquidtiger720
i dont know if this is even a problem, or is just caused by my commute.
my morning commute consists of 22 miles of freeway. the car has maybe 5 minuets before getting on that freeway. when i first start it, the car will slowly warm up. but lately i've noticed that after 22 miles of going 70-90mph, the temperature is only 1/4 the way up. as soon as i get off the freeway and go up a big hill, it slowly climbs up to the normal posistion and is at the halfway mark by the time i park. does anybody find it weird that the temperature gauge wont move up until i am off the freeway? do i possibly have a stuck gauge? or a bad temperature sensor? or is it just the commute? or possibly the thermostat?
by the way, im new to this board. i frequent bimmer.info and bimmerforums
liquidtiger720 is offline
post #2 of 4 (permalink) Old 12-01-2004, 08:04 AM
OutOnBail is an unknown quantity at this point
this is weird... u can try wheter ur gauger has a problem is: when u start ur engine (before travelling), turn on ur air cond... let's say to the highest power and observe in 2-3mins if ur gauger shows a good way up... u can go compare with other car and see how it goes... if the same thing happens, it might be some problem with ur heat exchanger path way around the mixing chamber housing(piston surrounding area) lets say the coolant is frozen in that pathway...
or ur gauger has a bit problem...
This is interesting, tell me how u go
OutOnBail is offline
post #3 of 4 (permalink) Old 12-01-2004, 10:25 AM Thread Starter
thanks for the reply. its been suggested that my thermostat is stuck open. i will try to check that out. if it is not that, then i will pursue your idea. thank you. anybody else?
post #4 of 4 (permalink) Old 12-01-2004, 03:22 PM
540i is an unknown quantity at this point
I would run with the Thermostat Idea. Seems to be the most common in these types of situations. Although it is very possible that your sending unit is kaput, I would start with the Thermostat. Pull it out, boil it in a pan of water and see what temperature it opens (if it's not stuck open). Once you see it open, run the thermostat under cold water, and see if it closes. Sometimes even when closed, it will open at a much cooler temperature than it's supposed to. Good luck, keep us posted please.
540i
540i is offline
Cooling System Help Needed vmelikRUS 3-Series (E36) 6 04-12-2005 01:30 AM
M3 Compression Test And Cooling System MadBMW M-Series (M1, M3, M5, M6) 0 03-10-2005 10:47 PM
Cooling system questions broketiltuesday 3-Series (E21, E30) 1 04-05-2004 04:57 AM
Engine cooling fan question 325iS 3-Series (E36) 5 10-01-2003 05:11 PM
