Where is the sensor for outside temp reading and what dose it look like? mine reads -40deg most of the time but will change some times is this a dud sensor or faulty?
You likely have a failed, or missing temperature probe. On my E39, this is in front of the right front wheel in the 'pod' between the wheel and front bumper. It is accessable from underneath the car - and is a black probe mounted up at an angle through the pod. Has a 2-wire clip attached. There is additional flashing mounted that partly obscures the probe location (also protects it, I suspect), but it is there.
Since the climate control uses this probe as part of the control logic, you'll want to get this fixed to allow the AC to work properly. Suspect it is less of an issue in heating mode..
I have same problem but i couldn't find the sensor i checked between the wheel and front bumper in right side .
I have E39 540i 1997 is it all E39 models they have same location of ambiant temp sensor ?
__________________ ــــــــــــــــــــــــــــــــــــــــــــــــــ ــــــــــــــــــــــــــــــــــــــــــــــــــ ــــــــــــــ
بي ام دبل يو
E39 540i 1997
E36 328i 1996
