I replaced the OSV on my '95 540 that fixed a severe oil burning. The oil burn in fixed. When the car was scanned at Dinan, the codes 1212 and 1213 popped up.
After some driving, 1212 went away, but 1213 is still there. The car idles rough, but as soon as it comes off idle it runs strong with no apparent issues. The MAF and idle control valve should be unrelated to the original issue. With the ingestion of so much oil, could this affect the injectors negatively? I'm going to check/replace plugs today.
Thanks,
Thanks,
