| I have a 94 530i with V8 M60 engine. I just had the intake off to fix the no return valve O rings but I can't seem to locate the oil separator on this engine. RealOEM shows something that looks like a water separator sometimes found on air lines, but I dont see anything that looks like that, I still have oil seeping around engine cover under intake and the return valve line are dry. Is it under a cover somewhere? |
