Oil pump is pumping engine out of my car! - BMW Forum - BimmerWerkz.com
Old 03-06-2004, 03:04 PM   #1 (permalink)
M5power is an unknown quantity at this point
well, i think i found out my problem with my oil leak and rpm jumps, on my 528E bmw, there is this line running from the oil pump and it goes above my distributor cap and the onto abyss; The oil is being pumped up that line and then the oil sprays out onto my frame and my powersteering(pump im guessing?) but yeah there is supposibly no oil going into my engine now and that is why it is running so crappy, does anyone know what could be causing this or what i could do to fix this? is it a new oil pump neeD? hope not since there 200 dollars . but any suggestions on where to look? i didnt get replys on my other posts about this kinda stuff but im hoping someone will look at it and give me some tips? thanks!
<img src='http://www.tehseen.net/david.jpg' border='0' alt='user posted image' />
The b0x that r0x
M5power is offline   Reply With Quote
Old 03-06-2004, 04:02 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
so your saying that the oil is spraying right? well perhaps your pump is ok are you sure the line is ok? check for cracks in the line.
Old 03-06-2004, 08:52 PM   #3 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
yeah do what furious says, and if you dont see anythign theres a very simple solution to find out your problem from there.. go to a dealer and pick up a bottle of oil dye, then get your hands on a black light pour the die into the engine turn it on and flash the light on it. works everytime.
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 03-06-2004, 11:42 PM   #4 (permalink)
sweet alrite, ima try to take a picture of exactally whats happening tomorrow so maybe u guys can get a better idea of wahts happening, but its not exactally spraying out of the pump, its running up some wire then falling off that wire, it looks like an electrical wire. ima check the line and also do taht dye test tomorrow, thanks for the tips and i'll keep ya posted!
The b0x that r0x
Old 03-07-2004, 03:38 PM   #5 (permalink)
well, i thought i'd ask a pro; i went to this shop down the street called autoban exotics. He kicked ass, he helped me out alot and told me my problem is probably my rocker shaft plugs and my camshaft seal, he said thats where it seems to be coming out of the most. to go about replacing these, i know the distributor cap and everything needs to be taken off but anything i need to expect that maybe someone else learned from when they did this? any suggestions will be great! and thanks for all the suggestions from everyone, hopefully my car will be up and running with no problems in no time! rebuilds are fun...
The b0x that r0x
Old 03-07-2004, 07:46 PM   #6 (permalink)
so i wanted to see if u guys could help me find where the rubber rocker shaft plugs are? i have a few pics of under my valve cover so maybe someone can point out where it is on the pic and lemme know, thanks!
The b0x that r0x
Old 03-07-2004, 07:47 PM   #7 (permalink)
and where exactally is the oil pressure switch at? i was told to check that for leaks. thanks
The b0x that r0x
Old 03-07-2004, 10:13 PM   #8 (permalink)
njtech is an unknown quantity at this point
M5,
the rocker shaft plugs are located at either end of the shafts in the head, lift the valve cover gasket up and you will see them. There are four, pry them out with a screwdriver. When you replace them, make sure that the slots are free of oil. The oil pressure switch is located next to the oil filter, pull the wire and see if any oil is there.(very common leaks) HTH
Steve
njtech is offline   Reply With Quote
Old 03-07-2004, 10:43 PM   #9 (permalink)
sweet, thanks nj i'll be fixing it tomorrow and let ya know how it goes.
The b0x that r0x
Old 03-08-2004, 06:07 PM   #10 (permalink)
GOT IT! well found out it was the oil pressure switch, the wire i was talking about that was spraying it all out was the wire that connected to it, i found out it was when the plastic part of it broke off when trying to take it off just wanted to say thanks for all the help and the great info from all of u, Later
The b0x that r0x
what engine oil to put in because i dont know if its syntec or normal? träumer 3-Series (E21, E30) 3 11-01-2005 02:40 PM
87 eta symptoms: clunk from the rear. engine noise.fuel pump buzzing need help träumer 3-Series (E21, E30) 3 10-05-2005 02:05 PM
Can Fix My Air Pump Problem, Check Engine Light Esme 3-Series (E36) 1 05-05-2005 12:33 AM
