Oil Pump Gasket And Oil Pump Bolts - BMW Forum - BimmerWerkz.com
Old 05-16-2005, 05:00 PM   #1 (permalink)
Cambridge's Avatar
Cambridge is an unknown quantity at this point
Send a message via AIM to Cambridge Send a message via MSN to Cambridge
I plan to take off the oil pan on my 95 540i tomorrow. Now that the car has passed the 100K mile mark, figured I better check the oil pump bolts that famously loosen and fall out.
A couple questions:
1) When I put in the new oil pan gasket (BMW #11 13 1 436 324) is there anything I’m supposed to coat it with? Or do I put it on as is?
2) Which color Loctite should I put on the oil pump bolts to lock them in? Is blue ok? Or should I use red?
3) To what value should I torque the bolts to?
Thanks for your help!
<img src='http://bmw-540i.com/images/540i/540i.jpg' border='0' alt='user posted image' />
<a href='http://www.bmw-540i.com' target='_blank'>My BMW 540i website</a>
Cambridge is offline   Reply With Quote
Old 05-16-2005, 05:18 PM   #2 (permalink)
billB's Avatar
oil pump cover 10 Nm
Sprocket to oil pump 10 Nm
oil pan to engine block 10 Nm....(for M6s)
Oil sump lower to upper section 10 Nm...all tens!
have fun
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
