Oil Plug Stripped! Now What ?? - BMW Forum - BimmerWerkz.com
Old 07-13-2009, 07:13 PM   #1 (permalink)
Funk 49's Avatar
Car: 94 530i M60 3.0L V8
Funk 49 is on a distinguished road
Exclamation Oil Plug Stripped! Now What ??
I went to the local Auto Lube this afternoon for an oil change on my 94 530i.
The mechanic there said that the oil plug was stripped and they would not proceed to take it out. He said he could tell by how "tight" it was already in the pan. He was afraid to take it out fearing they would be liable.
So, what should I do ?
Play dumb and take it to another shop and see if they'll be willing to take it out or what ??
o
Funk 49 is offline   Reply With Quote
Old 07-13-2009, 08:14 PM   #2 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
o
Take it to a repair shop.....if it is stripped....they can fix it with an enlarged self threading plug......
http://www.barnesdistribution.com/pd...le_241-260.pdf
johnny
Old 07-13-2009, 10:21 PM   #3 (permalink)
Car: Metamorphosis of the E34/92
Bimmermann is on a distinguished road
Exclamation
Play dumb and take it to another shop and see if they'll be willing to take it out or what ??o
Hello Funk 49:
You have to proceed with plans A, B, and C.
A) Decide what will you do if there is not enough boss material to go to a larger plug and the one in the car has stripped the threads. Are you ready for another oil pan? Yes. Then do it. - No. Go to plan B (though it eventually would have to be done).
B) Have the oil and filter changed where they pump it from the top (common and excellent method). Wait on the plug until the next change (insure there is no leak).
C) Have the plug drilled a hole 6 mm in diameter (Be sure the oil is caught in a pan, watch out for the mess). When all oil came out, with a stud remover carefully remove the plug. Now use a tap to check and reshape the female thread in the pan. Install a new plug and sealing washer to manufacturer's spec for torque (don't go where you did it last so the situation will not be repeated. neither go to the mechanic who refused to take the plug out). Proceed with oil filter change and oil replacement.
NOTE: If you are not tight for a few coins, have the oil pan loosened on the lowest end more than the other and drain the oil (carefull or will be really messy). Then remove the pan and do the plug removal on the bench.
For reinstalling the pan you will need a new oil pan seal. This approach gives you the advantage to remove all sludge and filings from the pan, sump filter, magnets and pump area (it'd be a very good thing), and to check the pan for leaks before you reinstall it.
Good luck, Bim
Bimmermann is offline   Reply With Quote
Old 07-14-2009, 09:36 PM   #4 (permalink)
Funk 49's Avatar
Thumbs up
Thanks Bim for the tips!
Old 07-15-2009, 12:42 PM   #5 (permalink)
Car: 06 525xi /e60
bimmernut is on a distinguished road
o
Funk,
Get yourself a gator socket! It works everytime. It will unscrew your stripped bolt. Good luck
bimmernut is offline   Reply With Quote
Old 07-15-2009, 01:06 PM   #6 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
OK so is the head of the bolt stripped or the threads?
1992 318i Coupe parts car
I am Captain Obvious
Old 07-16-2009, 05:08 AM   #7 (permalink)
Funk 49's Avatar
Arrow
Good question. I assumed he was talking about the threads were stripped.
I'll have to get under it and see for myself.
Old 07-17-2009, 05:36 PM   #8 (permalink)
abhicary is on a distinguished road
Take it to the dealer from where you have bought it?
BMW E46 2008 BMW Lights
abhicary is offline   Reply With Quote
Old 10-01-2009, 03:46 PM   #9 (permalink)
Car: 1987 325e 5-speed 2.7L
Steve8212 is on a distinguished road
Use a universal plug. I did it and never leaked a drop since then. Been over 2 years!
Steve8212 is offline   Reply With Quote
Old 09-18-2010, 02:45 PM   #10 (permalink)
rjp106 is on a distinguished road
Oil plug is stripped and just turns. Though something was funny when I took the old one off to make the change. It had 2 washers and one was broken. Wierd huh? Got it off and my problem happened when I tried to put the oil plug back in. Now I can't get it out. I guess I will just have to replace the oil pan. Not too sure how to get a spinning free oil plug out. Any one have any ideas?
rjp106 is offline   Reply With Quote
Old 10-07-2010, 11:13 AM   #11 (permalink)
Car: 1995 525i Calypso Red
Pete Lech is on a distinguished road
Broken Oil drain plug
Having just gone through this on my E34-M50, here is my experience:
BMW designed the drain plug to break first before it ruins the oil pan. Be happy about that!
I misread the Bentley Manual and torqued the plug to 44 lbs. When I next went to change the oil, the head of the plug off broke as I was putting it back in, even before I tightened it. I used a number EX3 Easyout to remove the old threads, which came right out. No drilling required as the threads were hollow at this point. It sure helps that the oil was drained out at this point, of course.
After looking at the way the plug is designed - it looks substantial but in fact is drilled down the center - I can see that 44 lbs was way too much torque. I used a new copper washer and tightened it securely but not too hard. (The other spec in the manual said 18 ft-lbs, but my torque wrench doesn't go below 25.)
Pete Lech is offline   Reply With Quote
stripped spark plug maybe a big prob seven 3-Series (E36) 8 06-18-2007 12:29 AM
Oil drain plug *HELP* topless_328 3-Series (E36) 15 12-06-2006 04:10 PM
spark plug drenched in oil Beemerguru 3-Series (E36) 2 10-06-2005 10:06 PM
Oil Plug eskiasu Product Reviews 0 07-16-2004 02:11 AM
where exactly is the oil drain plug?? EDawg 3-Series (E46, E90) 7 12-23-2003 01:50 AM
