Oil Leaking and burning in Engine Compartment - BMW Forum - BimmerWerkz.com
Old 01-16-2009, 03:27 AM   #1 (permalink)
jbriddle is on a distinguished road
Yesterday I checked the oil on my E39 BMW 530i and saw that it was a little low so I added a half quart. I went to work and everything seemed fine but today I went to work and while coming home I saw smoke coming out of the back of my car while I was on the highway for a mile or so. After pulling over in a parking lot I opened the hood to find oil by the rear of the engine and it was smoking. I am not getting any lights or check engine warnings. Is it possible I overflowed the oil and it is just coming out? I will check the oil level later to see if it is back to normal. Did I do irrepairable damage to my car? The oil pressure is good and runs great. HELP!!!! The car has 151,000 miles on it. Runs synthetic oil and is a 2002.
Thanks,
J
jbriddle is offline   Reply With Quote
Old 01-16-2009, 03:36 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Sounds like you over filled it, but cant understand the oil at the rear of the engine unless you have blown a gasket or seal due to the overfill and higher pressure, just keep an eye on it and see what happens, or you split some and it mad its way to the rear of the engine, only check oil and top up when car is level and stone cold.
Old 01-16-2009, 03:47 AM   #3 (permalink)
Thanks for the help. I was having some valve tapping and checked the oil after warming it up and going to the store to buy a quart, it only sat for 10 minutes before checking it and it was just under the full mark. If I check it in a few hours and it is lower than the full level should I drive it or consider it a goner?
Old 01-16-2009, 05:05 AM   #4 (permalink)
marti5's Avatar
The oil level is fine if it is between the low and high marks, as for the valve tapping, this is probably caused by a lot of small journeys.
Old 01-16-2009, 05:09 PM   #5 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
I dont think you did damage to it.. usually it is just the valve cover gasket leaking onto the manifold....
1992 318i Coupe parts car
I am Captain Obvious
Old 01-18-2009, 02:16 AM   #6 (permalink)
ozarkmark's Avatar
ozarkmark is an unknown quantity at this point
Mine has done this for about 40,000 miles but I have never noticed any smoke as a result. Usually when I change the oil, the bottom and and back half is covered in oil which I wipe off. It apparently doesn't use any oil either so I surmise it is a very small leak in one of the gaskets. I have over 220,000 miles now and it runs like a champ. Just saying....
1998 528i - sold 222,000 miles
1998 540i - sold 159,000 miles
2007 328i Coupe - 30,000 current
ozarkmark is offline   Reply With Quote
Old 01-18-2009, 06:59 AM   #7 (permalink)
Valve Cover gasket
My mechanic is looking at it and he said it is the valve cover gasket that is leaking. What could cause that to happen all of the sudden or is this something that was happening slowly and I didn't catch it?
Old 01-18-2009, 08:37 AM   #8 (permalink)
marti5's Avatar
They just go over time, they are the most common gasket to go along with the sump gasket, so dont worry, just get it changed or leave it, its up to you.
Would I change it ??? .... Yes.
Problem with oil leaking from Oil Filter adapter and maybe more??????? 325IConvertible 3-Series (E36) 12 07-16-2008 10:54 PM
Burning oil cap530 5-Series (E12,E28, E34, E39, E60) 7 03-21-2008 04:43 PM
Burning oil smell at idle aampsmb 3-Series (E46, E90) 2 12-31-2007 04:15 PM
E39 Burning Oil donaldm 5-Series (E12,E28, E34, E39, E60) 5 10-23-2004 03:46 AM
Car is burning oil.... 2.link 3-Series (E36) 8 12-23-2003 12:30 PM
