oil filter quickie - BMW Forum - BimmerWerkz.com
Old 04-22-2004, 12:56 AM   #1 (permalink)
2Crucial is an unknown quantity at this point
what tools do i need to change it?
should i use OEM or is Fram ok?
besides mileage, is there a good way to see if it needs changing?
thanks a lot guys!!
edwin
2Crucial is offline   Reply With Quote
Old 04-22-2004, 01:11 AM   #2 (permalink)
roguesniper1's Avatar
Car: 97 528i and 94 325i
roguesniper1 is an unknown quantity at this point
Send a message via AIM to roguesniper1
You can tell the quality of oil filter by the quality of oil. If oil is perfect clean, and I DO MEAN CRYSTAL CLEAN, then you can skip a cycle and change the filter next time. I change my oil every 3500 miles and filter every other oil change since my oil is always clean :lol: .
But that usually don't happen. My friends bimmer is little old and he changes filter with every oil change. But he does uses synthetic all the way and period of 5000 miles instead of 3500 like me.
FRAM oil filter is piece of crap. Don't ever use it. To tell you the truth I haven't seen a better filter than the OEM BMW one. You can even tell when you compare the compound of OEM to the FRAM one.
13mm box end wrench or socket is required for the oil filter cap. and 17mm socket is required to open the oil pan bolt.
ALSO, check the faq for step by step detail.
roguesniper1 is offline   Reply With Quote
Old 04-22-2004, 07:06 AM   #3 (permalink)
CiscoKid's Avatar
MANN filters are good... did anyone try the K&N filters?
Old 04-23-2004, 12:06 PM   #4 (permalink)
Car: 2006 E91 320d Touring
Verne is an unknown quantity at this point
a lot of people get on perfectly well with aftermarket filters, including Fram
Let there be light, sound, drums, guitar
LET THERE BE ROCK
Verne is offline   Reply With Quote
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
Spin-Flow Filter luvinangel Bimmer Talk/Motorsports Talk 6 07-07-2004 05:22 AM
