oil change on a 2003 525i - BMW Forum - BimmerWerkz.com
Old 09-13-2009, 03:27 PM   #1 (permalink)
fatarzan is on a distinguished road
Question oil change on a 2003 525i
i'm going to change my own oil for the 1st time -- having trouble locating oil filter -- is castrol syntec 5w30 ok -- any tips before i dive in ? thanks
fatarzan is offline   Reply With Quote
Old 09-13-2009, 03:33 PM   #2 (permalink)
Have you looked at realoem.com ?
Old 09-13-2009, 06:12 PM   #3 (permalink)
well i dove in -- the oil filter is on the upper right side of the engine -- a canister with a 26 mm nut -- the drain plug is 17mm -- i used castrol syntec 5w30 -- the castrol site says that bmw's high performance motor oil is a different blend but i think thats bull -- i would like to know how to reset the service indicator bar -- a small thing but a thing that bugs me none the less!
Old 09-15-2009, 10:42 AM   #4 (permalink)
rajk9800's Avatar
Car: 2001 525i E39 (RIP) 2001 525it
rajk9800 is on a distinguished road
BMW Oil Service reset for 2001 ~ current
No need for reset tool for 2001+ model
BMW insp. reset
- Iginition OFF (POS 0)
- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset.
rajk9800 is offline   Reply With Quote
Old 09-15-2009, 11:06 AM   #5 (permalink)
Mr. Clean
BimmerE39's Avatar
Yeah, you'd be correct when you say that Castrol's "special" blend is BS. I've been using Mobil 5W30 synthetic for 4 years now and never plan to use anything else. Aslong as the oils viscosity and weight is correct and it's synthetic you should be fine.
2003 525i Oil Changes and Maintenance REWYNN 5-Series (E12,E28, E34, E39, E60) 4 05-05-2009 08:10 AM
Bmw 525i 2003 Marco80 5-Series (E12,E28, E34, E39, E60) 3 08-01-2007 12:38 AM
Oil Change/oil Inspection Light Reset 2002 525i mssoetaert 5-Series (E12,E28, E34, E39, E60) 5 08-08-2005 05:42 PM
reseting oil bar after oil change on e36 LIMaxin 3-Series (E36) 6 08-26-2004 11:42 PM
Oil change 2003 325i mcatal 3-Series (E46, E90) 1 06-29-2004 01:19 PM
