Odometer BMW 528e 1983 - BMW Forum - BimmerWerkz.com
Old 09-07-2003, 06:07 PM   #1 (permalink)
Laloba is an unknown quantity at this point
Me again the non mechanic--My odometer is evidently stuck --has been reading the same amount of miles for 7 months..........could someone tell me what might cause this and what I can do --everything else on the panel seems fine ? unless I am missing something ............thanks
Laloba is offline   Reply With Quote
Old 09-09-2003, 10:34 PM   #2 (permalink)
roree is an unknown quantity at this point
The odometer is mechanical. It is run by gears. Probably the main drive gear has stopped engaging with the numeral gears. Outside of taking out the instrument cluster you can't fix it. Sometimes a good whack will reseat the gear cluster, if that's the problem.
roree is offline   Reply With Quote
Old 09-10-2003, 09:40 AM   #3 (permalink)
SoonerE39's Avatar
SoonerE39 is an unknown quantity at this point
Send a message via AIM to SoonerE39
It wouldn't suprise me if it needs a new speedometer cable. I don't know specifically for a BMW but they usually run from the transmission to the speedo. Could be a DIY for someone with moderate ability, assuming thats the problem.
[CODE]<EMBED src="http://members.cox.net/toakes2/Copy%20(2)%20of%20toms%20sig.swf"quality=high bgcolor=#000000 WIDTH=420 HEIGHT=220 TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/shockwave/...</EMBED>
Sig by Woobiee
<img src='http://www.ousooners.net/Avatars/Tx_Smack/lh_rip.gif' border='0' alt='user posted image' />
1999 528i 5 Speed, Sport Package, Confortti Software, Racing Dynamics Front Lip Spoiler and Rear Apron, Supersprint Muffler, Angel Eyes Upgrade.
SoonerE39 is offline   Reply With Quote
Old 09-19-2003, 08:40 PM   #4 (permalink)
105547111 is an unknown quantity at this point
Laloba,
I got a e28 528i and I had a problem that the odometer would read about 8 to 10 percent less than what the actual real travelled distance was. However the speedometer was reading correct speed.
Upon removing and disassembling the speedometer, I found one of the small gears was missing a tooth.
This gear was very small and is connected to a long shaft running behind the speedo face plate. I found it was hard and brittle, so that is most likely your problem as well, but your probably missing more teeth and its stopped.
I grabbed a speedo from the wreckers and made a great speedo from the two
Hope that helps!
105547111 is offline   Reply With Quote
Old 09-20-2003, 10:40 AM   #5 (permalink)
BMWhatever is an unknown quantity at this point
Suddenly your miles are considerable lower. Great when you're going to sell the car .:wink
BMW 518g touring (e34) -96.
BMWhatever is offline   Reply With Quote
1987 BMW 528e parting out SlaaberCC21 Cars For Sale 2 12-20-2007 01:36 PM
