Odd Window Issue???? - BMW Forum - BimmerWerkz.com
post #1 of 6 (permalink) Old 08-01-2009, 03:10 PM Thread Starter
N2Bimmers's Avatar
N2Bimmers is on a distinguished road
This is my first BMW and this may be an odd question. Anyone have any experience fixing windows and sunroof not closing/ rolling up unless the driver door opens? I have a 1992 525i...
Thanks!
N2Bimmers is offline
post #2 of 6 (permalink) Old 08-04-2009, 04:34 AM
Cam_uno's Avatar
Cam_uno is on a distinguished road
Could you please explain your problems a little clearer, most of us don't speak code.
"94" 518i Touring...What to do, what to do...
Cam_uno is offline
post #3 of 6 (permalink) Old 08-04-2009, 05:01 AM
rashid is on a distinguished road
I can understand some codes, I believe he has a problem with his electrical glasses & sunroof which is not working unless the driver door is open.
Really odd issue that requires someone understands the electrical circuit of the glasses & sunroof. If the electrical hub is within the driver door then the reason is understandable.
rashid is offline
post #4 of 6 (permalink) Old 08-04-2009, 07:36 AM Thread Starter
N2Bimmers's Avatar
Sorry for the encryption... Yes, it appears that I am having some electrical issues. I've scheduled a date with the mechanic to look at the issue. It seems that my windows and windshield wipers will only work if the doors are unlocked. Simply, if I unlock my door I can operate the windows, rolling up or down. And, while the doors are unlocked, I can turn on my wipers. The minute I lock one of the doors passenger or driver side door, the windows will not operate and the wiper will not continue to swing as if I turned the car off. Hope that's a little more descriptive for you... LOL! I wanted to know if someone had a similar issue. I'm sure something like this would not be common at all.
post #5 of 6 (permalink) Old 08-04-2009, 07:47 AM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute
I'd look at two things, and in the following order:
1. Fusible link (it's in a little black box on the positive lead leaving the battery); it's a metal fuse that can crack and cause all sorts of issues -- although very unlikely with your symptoms.
2. The general module (or GM for short). It's under the back seat on the drivers side under the big plastic cover ... it's a black box that sort of looks like a VHS tape; it says GM on it so you can't miss it. It controls pretty much everything electrics related ... when they go bad, they do strange things. I'd almost bet money on this being the cause of your troubles.
edit: The fusible link can be taken out and inspected for cracks; the GM you just have to replace with a known good one and see if that's it. I really doubt anyone can rebuild or correctly troubleshoot one.
Torque is offline
post #6 of 6 (permalink) Old 08-04-2009, 07:58 AM Thread Starter
N2Bimmers's Avatar
Thanks Torque, I'll check into it and let you all know my findings.
Odd turn signal issue. PaInBeLoW 1,6,7,8 - Series and Mini Cooper 3 03-26-2009 12:25 PM
Roof issue red light flashing! (and Sat Nav issue too!) doopranal Z3 / Z4 /ZM 0 03-24-2009 06:25 AM
Odd Tire wear=Odd Bushing Wear=me pissed off Numark318i 3-Series (E46, E90) 5 03-08-2009 01:46 PM
Window Switch Issue bonnerboy 5-Series (E12,E28, E34, E39, E60) 3 07-13-2006 11:21 AM
Need Help, Odd Starting Issue theogill 3-Series (E36) 0 09-24-2004 07:42 PM
