Occasional Stall Or Surge - BMW Forum - BimmerWerkz.com
Old 04-04-2005, 03:59 PM   #1 (permalink)
Essex502 is an unknown quantity at this point
You guys have helped me before and hopefully you can help me again. We are experiences an infrequent stall and twice have experienced a surge. The stall occurs only at idle. Never at higher RPM - only at idle. It has occurred when coming to a stop and at least once when first pulling out of the garage. No RPM fluctuation just dies. The surge occurred just recently when again at idle a small 1000 RPM surge happened. I haven't experienced that before in this car but the wife who drives its daily had it happen once before.
The particulars....97K miles on 2000 540IA. Always serviced when the interval lights indicate. The Service Engine light occasionally comes on but goes out before we can get it to the dealer.
Any ideas?
Essex502 is offline   Reply With Quote
Old 04-04-2005, 09:47 PM   #2 (permalink)
Desertracer is an unknown quantity at this point
Replace the MAF (Mass Airflow Sensor) mine (99 540IA) and others have had the same problems.
Nick
Desertracer is offline   Reply With Quote
Old 04-05-2005, 01:51 PM   #3 (permalink)
Papa_Bimmer is an unknown quantity at this point
Wow. I'm having the same problem. I just purchased a Certified/Pre-Owned 2000 528i at 59k miles about three weeks ago. Noticed it when I test drove it. Made a note to the salesperson. She is excellent by the way. She sold the car when it was new and took care of the owner everytime there was a maintenance to be done. THe car had detailed maintenance records. Car looked like it had hardly been used. No wear and tear on the interior or exterior at all. Anyway, when I first turn the car on, it sits at 750RPMs. Then after three minutes, the RPMs dip to 500 and the engines shakes as if it's about to stall. Then it "recovers." But ten seconds later, it dips back down to 500RPMs again, almost stalls, then recovers. It does this every ten seconds. But after I drive it for a while and sit at a red light or whatever, it runs smoothly. I sent the salseperson an email and they are going to take care of it. It's still under warrenty which is cool.
If you're in the DC area and would like a real nice salseperson to talk to about a new or used car, ask for Nan Wong. Nicest salesperson I ever met and will bend over backwards for you. She's been there for 13 years. I guess that says something about her service.
Papa_Bimmer is offline   Reply With Quote
Old 04-05-2005, 01:52 PM   #4 (permalink)
Ooops. Forgot to give the name of the dealership. That's Nan Wong at VOB BMW in Rockville, MD. Very nice lady. I recommend her to anyone looking to purchase a BMW.
Old 04-07-2005, 08:41 AM   #5 (permalink)
Thumbs down
Now the wife is reporting a intermittant "pulsing" of the engine RPM. It will be steady for about 30 seconds "at the line" and then pulse to a higher RPM for about 5-10 seconds and drop back down to normal. Her term "at the line" is the gradation line on the tach where the needle normally points. Does this help diagnose the issue?
idle rpm surge.... again SD318is 3-Series (E36) 2 11-03-2005 09:27 PM
'87 325 Stall tikishow 3-Series (E21, E30) 3 04-01-2005 02:48 PM
Idle Stall brien4787 3-Series (E36) 2 10-21-2004 08:51 PM
Occasional starting problems MSbimmer 5-Series (E12,E28, E34, E39, E60) 1 08-28-2004 12:34 PM
Occasional Vibrating Steering Wheel gabeshmabe 3-Series (E36) 7 07-13-2004 09:12 AM
