Obc - BMW Forum - BimmerWerkz.com
Old 01-25-2007, 02:49 PM   #1 (permalink)
keithslippery is an unknown quantity at this point
Obc
Hi guys a little help needed if possible....
1991 535i sport..
Today my OBC seems to be not working properly, the time and date works, but the consumption just stays on - - - on 1 and 2, the range is just stuck on 189m and temp reads +65, yesterday all was fine and working ok, have done nothing to car since then, any ideas..
cheers
keithslippery is offline   Reply With Quote
Old 01-28-2007, 11:38 AM   #2 (permalink)
Car: 1993 E34 530i
miniman_7 is on a distinguished road
sounds like
a computer reset is needed.
either disconnect the battery, and leave for 5-10 minutes (it may be worth touching the disconnected lead against the other to clear any residual charge) Then reconnect.
Or
Pull out the computer unit from under the bonnet (it will be under the screwed-down black lid, usually the one nearest the inside of the car)
Leave a couple of minutes, then plug back in.
Hopefully this should clear the issue.
Good luck!!
miniman_7 is offline   Reply With Quote
Old 01-28-2007, 12:57 PM   #3 (permalink)
Cheers miniman, will try the computer unit first now.
if no luck will try battery tomorrow.....
it couldnt be the obc being knackered could it....
Old 01-28-2007, 01:40 PM   #4 (permalink)
ok have tried disconnecting everything inc battery, for at least half an hour and still consum and speed - - - and range is now stuck on 80m.
OBC Conversion 318itx 3-Series (E36) 8 05-06-2007 04:47 AM
2nd post, someone please help with OBC issue seths540 5-Series (E12,E28, E34, E39, E60) 6 09-14-2006 03:36 AM
Digital speed Il_Simo 3-Series (E36) 58 05-04-2006 05:47 AM
obc 11 ro obc 18 swap cabrit 3-Series (E36) 4 03-27-2006 03:14 PM
Any info on how to install a OBC on a 318ti? Stones 3-Series (E36) 5 01-05-2006 04:55 PM
