noisy tranny (before warming up) - BMW Forum - BimmerWerkz.com
Old 12-03-2003, 12:56 PM   #1 (permalink)
chuck540owner is an unknown quantity at this point
Hi all! This is mt first post but I have read many of the troubles some of you have been going through. This is my first Bimmer and I am excited to own it. This site is a great source of info and I'll be checking here often.
My question is about the automatic transmission. It's a 95 540i with 77,000 miles. Lately the temperature has been in the upper 20's and the tranny sounds like it's not feeling well. This goes away when the engine is almost at operating temp.
Probably normal is my guess. Thanks in advance.
chuck540owner is offline   Reply With Quote
Old 12-03-2003, 01:11 PM   #2 (permalink)
lwebb12's Avatar
Car: 2000 M5
lwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond repute
Send a message via AIM to lwebb12 Send a message via Yahoo to lwebb12
when is the last time you have had it serviced? also cold may affect the viscosity. I know that manual transmission suffer from difficulty in moving the selector into the different gates when cold.
Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
lwebb12 is offline   Reply With Quote
Old 12-03-2003, 01:29 PM   #3 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
can you be a little more specific at all? like noise or symptoms?
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 12-03-2003, 01:53 PM   #4 (permalink)
Owned it two weeks, Don't know about last servicing.
It makes a wining noise. Only way I can describe it. Otherwise it operates smoothly.
Old 12-03-2003, 02:26 PM   #5 (permalink)
CBA
CBA's Avatar
whining is usually the result of little or no fluid in the tranny.. run the car to operating temperature and pull the dip stick and see..
also take a sniff of he fluid see if its burned.. maybe time for a tranny service..
hope that helps you out..
keep us posted on what you found. and aboard
-Founder
Old 12-04-2003, 06:17 AM   #6 (permalink)
I can't find the dipstick for the transmission fluid. Any idea where it resides? The oil pan seal in leaking so I suspect that the fluid is low. I might as well replace it and the filter as well.
Old 12-04-2003, 06:31 AM   #7 (permalink)
CBA
CBA's Avatar
im pretty sure that the tranny isnt sealed check on the left side of the engine somewhere(not sure on this),
but yeah time to replace.
-Founder
Old 12-04-2003, 10:27 AM   #8 (permalink)
There's no dip stick that I can see and I've been all over and under also. The owners manual doesn't make any reference to it. Seems to me the problem is that the tranny is too far back and under the body for easy access to it.
Old 12-04-2003, 12:29 PM   #9 (permalink)
CBA
CBA's Avatar
wow, lol must be a sealed system then.. id go have it checked by a certified technician..
-Founder
Tranny Slams On Auto Mode wango 3-Series (E36) 2 09-02-2005 07:29 PM
Tranny Auto To Manual mmclaren 3-Series (E36) 15 03-11-2005 12:27 AM
Tranny Problem sajco 3-Series (E36) 2 02-15-2005 09:00 AM
Put an 82 528e tranny in a 96 535i? ronskal 5-Series (E12,E28, E34, E39, E60) 2 06-09-2004 04:29 PM
tranny blues 3two5 3-Series (E21, E30) 8 03-18-2004 01:30 AM
