noise under my car? - BMW Forum - BimmerWerkz.com
Old 07-01-2006, 11:55 AM   #1 (permalink)
kman's Avatar
kman is an unknown quantity at this point
noise under my car?
there some strange noise under my 528. it sounds like metal part hiting another metal part. its a "clink clink" noise. when i check under the car nothing was loose. i can hear it sometimes when the car is just moving, and alwals hear it when i hit a bump in the road ora dip. what is it?
kman: THE CHERRY BOMB GLASSPACK GUY!
GLASSPACKIN SINCE 12/2007
b5.5 passat 1.8t gls
e24 635 csi
kman is offline   Reply With Quote
Old 07-01-2006, 01:17 PM   #2 (permalink)
Car: E39 & E46
16valex is on a distinguished road
you may have some stones caught behind the wheel rotor back plate. if not then try to replace your stablizer links( the end parts).
Alex
16valex is offline   Reply With Quote
Old 07-01-2006, 02:26 PM   #3 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Most likely sway bar links.
Old 07-01-2006, 03:03 PM   #4 (permalink)
cnn
cnn is on a distinguished road
Loose Heat Shields
I did the write-up and posted it here:
http://bimmerboard.com/forums/posts/196703
cnn
98 528i
cnn is offline   Reply With Quote
Old 07-02-2006, 02:35 AM   #5 (permalink)
kman's Avatar
cnn
98 528i
ok thanks alot, ill check the out tomorow
e24 635 csi
Old 01-12-2009, 09:35 PM   #6 (permalink)
miro1969 is on a distinguished road
HI
I’m pretty new to this forum as well and I seem to be having similar problem with my 2000 528i with 90,000Miles.
When driving slow and hitting bump I could hear the clunking noise coming from front suspension (I hear it coming from the driver side). When driving at the speed between 50-60mph I feel little vibration on the steering wheel as well as I hear like wobbling noise(sounds like loose part vibrating, etc) coming for the same area.
I have mechanic look at it and he claimed he checked bushings, arms and stabilizer links and everything seem to be tight. He says it maybe steering rack that is causing this noise and suggesting replacing steering rack.
Also, I want to mention that I don’t feel any play when moving steering wheel, feels perfectly smooth, not any kind of noise.
Has anyone experience same or similar issue? Any ideas?
Do you think steering rack should be replaced?
Your help/opinion would be greatly appreciated
M
miro1969 is offline   Reply With Quote
Old 01-12-2009, 10:03 PM   #7 (permalink)
It could be worn lower control arm bushings.
Old 01-13-2009, 10:22 PM   #8 (permalink)
Control arms and bushings seemt o be tight.
Still not sure what it can be. Noise can be heard when going slow over the bump, but dontreally feel anything on the steering wheel at that point. When going faster it is not noticable until i hit 50 tom 60mph, then start feel a litttle vibration on the steering wheel and hear like loose metal parts whabling, from the same area the noise is coming(driver suspension side) when hitting bump, patwhole while driving slow......
I guess I will have to go with tech recomendation and replace steering rack, hope it will resolve the issue.
Old 01-18-2009, 02:23 AM   #9 (permalink)
ozarkmark's Avatar
ozarkmark is an unknown quantity at this point
Hi Miro - I too believe it is your lower control arm bushings and maybe you are due for some new front struts. I realize you didn't mention this but I would rule out wheel bearings. Those will eventually need replacing too. For now, focus on the lower control arm bushings and struts. They may feel tight to a mechanic but when I replaced mine, it was like NEW again.
Think cartilage in the joints when it comes to bushings.....
1998 528i - sold 222,000 miles
1998 540i - sold 159,000 miles
2007 328i Coupe - 30,000 current
ozarkmark is offline   Reply With Quote
Old 01-18-2009, 03:18 AM   #10 (permalink)
84bmw318i's Avatar
Car: 91' 318ic
84bmw318i is on a distinguished road
Send a message via AIM to 84bmw318i
i had i similar problem and it turned out to be a loose heat shield
84bmw318i is offline   Reply With Quote
Old 02-03-2009, 12:55 AM   #11 (permalink)
Car: 530i-2002 & E280-2007
rashid is on a distinguished road
miro, I am having exactly the same problem & I have also received the same advise of the stearing rack ..... let us have a clear plan to find the problem ... I suggest the following steps (based on the above advises):
1. check the heatsheilds.
2. check the lower control arm bushings
3. Finally you should check the stearing rack becuse it is too expensive to replce it
Let us know the result ....
rashid is offline   Reply With Quote
Old 02-03-2009, 01:08 AM   #12 (permalink)
can it be the shock absorbers??
Old 02-03-2009, 08:23 AM   #13 (permalink)
Actually it was a steeering rack, apparently it is not common issue but it was in my case, the noise seem to be coming from the area where the rack is conected with steering column/box.
Replace it with used rack and noise went away
thanks for your suggestions,
Old 02-04-2009, 09:51 PM   #14 (permalink)
That is ok miro, what was the price of the used rack? I may buy one as the problem is the same I/ve got the same advise also ..
Old 02-04-2009, 09:56 PM   #15 (permalink)
I got it really cheap for $250 at the auto recycler and replaced for $270.
Noise in your system? da_bull Audio and Electronics 2 05-15-2013 03:27 AM
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
