No Heat - BMW Forum - BimmerWerkz.com
Old 02-02-2011, 08:18 PM   #1 (permalink)
KeyzBimma is on a distinguished road
No Heat
2003 540 only generates heat when its coming the faster i drive the more heat I get. I got the fan gear changed last week. Check coolant level is on Mechanic says its a false reading......I think i need a new mechanic also
KeyzBimma is offline   Reply With Quote
Old 02-02-2011, 10:51 PM   #2 (permalink)
Has the heater core been checked?
Old 02-04-2011, 01:43 PM   #3 (permalink)
Patrick-BMWPartsSource is on a distinguished road
Final Stage Unit 64-11-6-923-204 $90.95 our price and lists for $116.60 in stock !!
Patrick-BMWPartsSource is offline   Reply With Quote
Old 02-12-2011, 02:48 PM   #4 (permalink)
Siouxperman is on a distinguished road
Sounds like the final stage unit, also called blower motor resistor. Pretty common problem and bout 15-30min to change it out. AutohauseAZ has them for about $50
Siouxperman is offline   Reply With Quote
Old 02-19-2011, 02:53 PM   #5 (permalink)
Slow Driver is on a distinguished road
Check your thermostat. The plastic luggs holding the Thermostat may be broken and is now ot seating properly. It is a quick job. Make sure the engine is cold.
Slow Driver is offline   Reply With Quote
Old 02-22-2011, 03:46 PM   #6 (permalink)
Car: 1986 528e Auto,
gidgaf is on a distinguished road
Mine's the same. My finger says there's coolant there, but the sensor says it's not.
Does the fan itself work? As in:
Do the heater/ dash/ defrost switch positions work?
Do the fan switch positions correspond to proper air flow?
Is your water temp gauge reading a constant display?
Sometimes the problem is just a symptom ...
gidgaf is offline   Reply With Quote
No Heat gwee1966 3-Series (E21, E30) 15 02-24-2009 08:03 PM
A/C and heat help selvisa 3-Series (E46, E90) 1 10-24-2008 12:44 PM
No Heat! chap0223 3-Series (E21, E30) 6 02-03-2007 09:27 AM
No Heat! kylek325i 3-Series (E36) 7 01-28-2006 04:15 PM
Heat? ghettozn 3-Series (E36) 3 08-02-2004 08:22 PM
