No Fuel - BMW Forum - BimmerWerkz.com
Old 06-20-2005, 07:05 PM   #1 (permalink)
tkb
tkb is an unknown quantity at this point
My 1985 535i drove just great at noon. Parked it and shut it off. Came out after work and it turns over but no fuel to the engine (I know it's fuel because I can usually smell it anyway, and now no smell at all in the engine compartment).
So ... my first guess is fuel pump - is that a good bet?
Tom
tkb is offline   Reply With Quote
Old 06-21-2005, 12:45 AM   #2 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
Fuel pump, clogged fuel line, possibly just the fuse for the fuel pump.
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
d3ity is offline   Reply With Quote
Old 06-24-2005, 07:10 AM   #3 (permalink)
When you get the fuel pump or whatever fix get the smell of fuel under the bonnet checked before it goes up in flames
Old 06-25-2005, 12:20 AM   #4 (permalink)
sometimes if you tap on the fuel pump relay, if the relay is starting to go bad you can get it to start so you can atleast get it home or wherever you need.
Old 06-30-2005, 01:57 AM   #5 (permalink)
This doesnt make sense.
There should ALWAYS be residual fuel pressure in the line - enough to start the car for sure.
Perhaps all that time you were smelling fuel, you had a fuel leak (very dangerous) and either a relay, pump or fuse has bit the dust and the leak has let out enough pressure to not allow the car to start.
As someone above has said, get the smell checked out immediately - then diagnose.
Old 07-03-2005, 03:06 AM   #6 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
When you do put fuel into it does it run well? If it does I doubt the fuel pump. That smell uhh.....isnt a good sign. Take it to a shop, this is a serious issue.
Fuel Leak ajreich 3-Series (E36) 1 11-13-2005 08:00 AM
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 05:51 PM
Help Urgent Bmw 318is Fuel Flood Help nobrakese36 3-Series (E36) 1 07-25-2005 11:31 PM
