Nissens vs Behr Radiator for E34 525i? - BMW Forum - BimmerWerkz.com
Old 01-21-2004, 10:56 PM   #1 (permalink)
dpico is an unknown quantity at this point
Thumbs up
I need to replace the radiator on my '93 525i. A local BMW shop (not the dealer) recommends Nissens over Behr (which is OEM). He said Nissens are built better and last longer. Has anyone else heard this?
dpico is offline   Reply With Quote
Old 01-22-2004, 05:58 PM   #2 (permalink)
TECH's Avatar
I can't speak for Nissen, but Behr seems to suck.....at least some of them. The ones on the newer e39 are constantly cracking below the upper rad neck.
Old 01-22-2004, 08:32 PM   #3 (permalink)
Post
Thanks TECH! I also found out why Nissen (aftermarket made in Sweeden) is better than Behr (OEM). It's because Nissen uses 100% new plastic for the resevior tank while Behr uses recycled plastic. This explains why the plastic reseviors on the Behrs tend to leak, because they have weak points from using recycled plastic.
Old 05-01-2004, 02:53 PM   #4 (permalink)
kenholio is an unknown quantity at this point
Behr Rad's are designed to fail after 5 years
kenholio is offline   Reply With Quote
Old 05-01-2004, 04:27 PM   #5 (permalink)
TheHire's Avatar
Car: 92' 525(RIP), 03 530
TheHire is an unknown quantity at this point
I heard Behr makes it that way intentionally to keep them in business . I also have a hairline crack on the driver's side ghead . It's not bad, but will have to replace it soon.
<img src='http://img106.exs.cx/img106/6505/thehireskawful1.jpg' border='0' alt='user posted image' />
TheHire is offline   Reply With Quote
Old 05-01-2004, 04:29 PM   #6 (permalink)
TheHire's Avatar
Please let me know which one you going with (altho now it's obvious thatz it's gonna be Nissen) and where you getting it from. Price and installation too . Thanks in advance !!!
Good luck.
95 525i engine TDC w/VANOS yaofeng 5-Series (E12,E28, E34, E39, E60) 0 11-06-2005 05:39 PM
E28 - Is The Radiator The Same On The 525i & 528i? roscoa1 5-Series (E12,E28, E34, E39, E60) 0 01-08-2005 02:28 PM
325i vs 525i Bengal94 3-Series (E46, E90) 2 10-25-2003 09:51 PM
