Nightmare Overheating Smoking - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 05-31-2006, 06:14 PM Thread Starter
pawea is on a distinguished road
Angry Nightmare Overheating Smoking
Hi folks dont know too much about bmw 5s, i have a 1998 523i which has been giving me problems for a few weeks,the temp gauge was rising into the red every now and then then returning to normal very quickly with the smell of burning oil now and then for weeks on end,however my wife was driving the car last week when the temp gauge went into the red and the car stalled and could not be restarted.After towing it home i found no sludge or deposits on the oil cap or dipstick but the car was difficult to start at first and ran rough at low idle with white smoke comming from the exhaust.Once driven above 20mph all seems fine i suspect the head gasket but would like a more expert opinion.Is it safe to continue to drive the car like this as i use it for work
cheers
pawea is offline
post #2 of 8 (permalink) Old 05-31-2006, 06:20 PM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute
You should have sorted that out as soon as it started to overheat. You'll be lucky if you just need a new head gasket ... you most likely warped the head too. I would definitely stop using the car because if it hasn't been completely ruined by now, it soon will be.
Just my 2c.
Torque is offline
post #3 of 8 (permalink) Old 05-31-2006, 10:35 PM
cnn
cnn is on a distinguished road
All these issues were posted by myself here
cheers
I did the Entire Cooling System and did the write-up here:
http://bimmerboard.com/forums/posts/199986
http://www.babcox.com/editorial/us/us80222.htm
HTH.
cn
cnn is offline
post #4 of 8 (permalink) Old 05-31-2006, 11:59 PM
d3ity will become famous soon enough d3ity will become famous soon enough
One rule about BMW cooling systems.
You have aluminum heads, the temperature guage is meant to sit right in the middle and never go past it, if it moves away from that center mark, you have a problem, pull over and get it towed. That said, I don't always keep an eagle eye on my temp sensor, I've overheated my car several times due to a few odds and ends breaking... I've even pegged it into the red once. I managed to survive.
It might be advisable to get the heads checked if the car has been repeatedly, and severley overheated. Go to a mechanic you trust and know for this. Heads are an expensive job...90% of mechanics, and 100% of dealers, will simply just tell you the heads need to be replaced. Your problem may not specifically be the head gasket, but those aluminum heads could have warped under the heat. This is the worst case scenerio, but is one you need to consider. If you're just burning oil, check the spark plugs and figure out whether you're oil fouling them. Then you can start troubleshooting that. One step at a time, start with common problems and work your way up. But that kind of overheating needs to be resolved immediatley. The overheating is not your current main headache as you said, you're worried about the head gasket...but it won't get any better until you resolve your cooling issues.
If you do continue to drive the car, do so VERY carefully and watch that temperature guage.
d3ity is offline
post #5 of 8 (permalink) Old 06-01-2006, 02:58 AM
Moderator
Dirty_Tool's Avatar
Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute
runs rough and white smoke out the tailpipe after overheat.... You can just about be 100% sure the headgasket is blown. Beyond that you could have cracked or warped head. Best thing to do is remove the cyl head, send to machine shop have it pressure tested for leaks and straight edged to see if it is warped or not. If you have water in the oil on a BMW you can be pretty sure that the head is cracked. if its just coolant entering the combustion chamber you may get lucky and just need a headgasket.
Best of luck,
DT
Dirty_Tool is offline
post #6 of 8 (permalink) Old 06-01-2006, 10:08 AM
325isBaby's Avatar
There is some really great input here...BMW's really don't respond well to multiple overheated states...Good luck
Come see me at MySpace
325isBaby is offline
post #7 of 8 (permalink) Old 06-14-2006, 11:03 PM
e39 5ive is on a distinguished road
Send a message via MSN to e39 5ive
Just recently went through this same issue. Diagnosis, CRACKED HEAD, AAARRRGGGHHH! Common problem, expensive fix. Don't drive the car until you get it sorted.
Anytime that temp needle moves on a BMW, spells problems. I think it has something to do with weak points in thin walls of cylinder head. Whatever caused overheat also caused pressure gains. Weak spots in head give under that pressure. From what I heard, it's a design by BMW to save on weight. My problem started with a cracked plastic thermostat housing. SUCKS BIG TIME.
Make sure you send head to be pressure tested. Good luck.
e39 5ive is offline
post #8 of 8 (permalink) Old 06-15-2006, 05:25 AM
da_administrator
da_bull's Avatar
da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute
Ask me how I got the privilege of refinancing my car for another 2 years. $2300 later I had a new head, water pump, Inspection 1, timing belt, etc. etc.
da_bull is offline
Overheating Gabrielpr12 3-Series (E21, E30) 21 09-23-2005 09:09 AM
Engine Overheating doughnutboy 3-Series (E36) 11 06-13-2005 02:10 PM
Overheating Problem & Stiff Radiator Hose ?? viluve 3-Series (E36) 6 10-30-2004 01:39 PM
Overheating StevO 3-Series (E36) 4 09-07-2004 04:52 AM
