Newbie with a problem - BMW Forum - BimmerWerkz.com
Old 05-12-2010, 10:12 AM   #1 (permalink)
make mine an aston is on a distinguished road
Hi all, i'm new to the site and to BM ownership. I've just bought a 98 E39 520 in pretty average condition, while i was vacuuming the carpets i looked under the front seats and noticed that all the wires from the seats had been cut. I Know these wires are for the airbag sensors (the airbag warning light is on) but i can't understand why they would be cut. I want to reconnect them but I'm worried about the airbags going off if i do!
Can anyone think of any reason apart from trying to put the warning light out, that anyone would cut them?
Great site and forum, already helped alot.
Thanks
make mine an aston is offline   Reply With Quote
Old 05-13-2010, 07:44 AM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Welcome to the Werkz
All the wires on both front seats are cut, or just the front passengers?
If they are all cut, none of the electric seat functions will work. What they were most likely trying to do was cut off the occupancy sensor mat on the passengers seat which is prone to failure, you can make up a fairly cheap circuit to overcome that issue, but you will need the error code cleared to get rid of the warning light. To avoid any triggering issues, just disconnect the battery and then start your repair work, make sure you insulate the repairs and position the wires so that they don't get pinched or over tensioned when the seat is moved. The occupancy sesnor mat wires usually run up the base of the back seat and are just visible in the middle of the seat base when view from the rear seat foot well (normally 3 wires from memory)
Old 05-13-2010, 10:08 AM   #3 (permalink)
Thanks for the reply Brettski, i guessed that was it what done for but just wanted to make sure.
Will disconnecting the battery clear the codes or is that an OBD job?
Old 05-17-2010, 02:55 PM   #4 (permalink)
Car: BMW E39 525 TDS SE '96
r1bby is on a distinguished road
OK depends on your seats. Your drivers seat will have 2 wires to the seatbelt restraint system, your passenger seat will have the two same black wires plus a set of colour wires for the occupancy seat sensor. You can buy a little box to act as a bypass socket to plug into the colour wires of the occupancy sensor but you'll need to rewire the seatbelt restraints and buy a reset tool (approx £50) to remove the airbag light from the dash. (unplugging the battery just won't work)
Any other wires that may be cut could be electric adjustment, heated, side airbags or a mixture of the three. The most likely reason why they're cut is someone has replaced the seats for more or less expensive seats at some point in the past. There are a number of sockets for each type to add to the confusion so it seems like this guy just thought sod it and cut them.
r1bby is offline   Reply With Quote
Old 05-17-2010, 08:37 PM   #5 (permalink)
roma's Avatar
roma is on a distinguished road
is airbag light on? or when you start the car does seat belt light stays on ,and when you work airbag ,disconect batery and do not stay front a airbag
roma is offline   Reply With Quote
Old 06-07-2010, 08:35 AM   #6 (permalink)
Thanks for the help guys.
I've seen those bypass boxes on Ebay, they seem to range from 99p to £9.99, has anybody had any experience of these ie do they work?
newbie with weird problem.... squaddiemarc 3-Series (E36) 1 05-02-2010 07:45 AM
Newbie..Key problem..help! k1121c 5-Series (E12,E28, E34, E39, E60) 5 06-03-2009 08:47 PM
Newbie with 316i Heater problem Barmac 007 3-Series (E36) 2 01-12-2009 03:15 AM
Newbie. E39 problem stig101 5-Series (E12,E28, E34, E39, E60) 6 03-15-2006 09:26 AM
Newbie Hello And Quick Problem! ///M3 3-Series (E36) 4 01-12-2005 09:01 AM
