Newbie. E39 problem - BMW Forum - BimmerWerkz.com
Old 03-13-2006, 12:34 PM   #1 (permalink)
stig101 is on a distinguished road
Newbie. E39 problem
Hello all.
New to the forum,well I have been here for a while but not registered till now .
I own a 1999 E39 528i for about 3 months now , great car. but I have been having some problems I'll appreciate any help with. check engine light it just keeps coming back every time I erase it with no error codes what soever , I have read from previous post here that it could be an air pump issue (where is the airpump )or an o2 sensor ? but if it is should'nt I get an error code ?
thanks for any help .
stig101 is offline   Reply With Quote
Old 03-13-2006, 03:52 PM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
If you believe it is the air pump it is located on the right side of the engine compartment (could be next to shock tower) and looks like:
Come see me at MySpace
Old 03-13-2006, 04:27 PM   #3 (permalink)
325isbaby thnx for ur reply what is this airpump for anyways , and is there any way I can check it if it is bad.
thanks again.
Old 03-13-2006, 04:33 PM   #4 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Just wondering, how many miles on your car?
LOS
Old 03-13-2006, 04:49 PM   #5 (permalink)
about 78000...
LOS do you think it could be the o2 sensor? I do suspect it is that but the car runs fine and the m/Gallon is spot on ...
Old 03-14-2006, 06:10 PM   #6 (permalink)
CosmosBlack's Avatar
Car: 2002 Porsche C4S
A good bet is the Mass Airflow sensor, if that has not been replaced yet.
It's about a $400 job.
Old 03-15-2006, 09:26 AM   #7 (permalink)
LOS
LOS's Avatar
http://www.bimmerzone.com/fcodes.htm
As you know, our cars have 4 sensors. I only replaced 2 when I hit 78k. My light did come on and got a code... Are you using the righ tool? The peak reader costs around $150. checkout the link above for codes.
Even if it was the mass flow sensors, you should get a code on your reader! Right?
Also, check autohausaz.com if you decide to buy the sensors. they usually have good prices on parts.
E39 Washer jets - common problem? PeteV 5-Series (E12,E28, E34, E39, E60) 8 10-29-2011 10:25 AM
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
E34 trans prog problem exacerbated electronblue 5-Series (E12,E28, E34, E39, E60) 5 03-02-2006 10:07 PM
Perplexing Problem Starting my 87 528e arkhaus 5-Series (E12,E28, E34, E39, E60) 5 02-04-2006 08:17 AM
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 0 02-28-2005 07:33 AM
