Newbie, bought a 95 740 iL with a couple problems - BMW Forum - BimmerWerkz.com
Old 09-12-2011, 05:28 PM   #1 (permalink)
zukgod1 is on a distinguished road
Hello all,
Thought I would drop in and say hi.
I just bought a 95 740iL, absolutely beautiful car.
It has a couple issues but sense I run a tire/repair shop I think I can deal with them ok.
Needs a tie rod assy and control arm on the right front and some front brake rotors.
Now for the real issue.
It has a rough idle. I've replaced the BOSCH +4 plugs with NGK's, ran some injector cleaner through it and SeaFoamed it as well (3 times).
While it idles a bit better it's still not good.
I stuck a vac gauge on it and it has erratic vac at idle which tells me the valves are not seating properly.
215k miles.
So....... I have a new (to me) 98k mile engine being delivered in the AM.
I would rather not swap engines as I tend to get REALLY carried away, Timing chains, valve cover gaskets, pan gaskets, water pump. etc etc.. I just tend to go nuts.
Last time I did this I ended up completely refreshing the damn "Good used engine" before I even had the old one out.
Any suggestions before I pull the engine?
Thanks..
zukgod1 is offline   Reply With Quote
Old 09-13-2011, 05:56 AM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Welcome to the Werkz. Always good to have another 7er on board.
Have a close look at the intake manifold and the intake ducting between the MAF and the throttle body. My 740iL (M62TU engine) had leaks between the throttle body and the manifold, others have found cracks in the plastic ducting. Way easier to fix up a few vacuum leaks than changing the whole engine.
Riding in style
Old 09-13-2011, 09:33 AM   #3 (permalink)
I've checked the intake over pretty good.
Even did a Smoke test and the only smoke that came out was out the tail pipe and air filter.
Then there is the bouncing vac gauge.. An intake leak wont case that.
This morning it sprung a PS leak as well..
Old 09-14-2011, 05:49 AM   #4 (permalink)
brettski's Avatar
I am not sure if this could have the effect that your experiencing, its from the later motor, but worth considering. If you start the engine and let the idle settle, pull the engine oil dipstick and listen to the idle and for a slurping noise from the dipstick tube. If the idle drops and you do have a slurping noise it is most likely a diaphragm issue on the intake manifold rear cover (OSV). Not a really big issue, but its a bit of a pain to replace. Given you've got the tools and facilities it is probably a piece of cake for you to change. Have a look at part #2 in this diagram.
RealOEM.com BMW E38 740iL Intake manifold system
Rear Manifold Cover aka. OSV | BMW 740iL | Magnum
Riding in style
Old 09-14-2011, 06:08 AM   #5 (permalink)
brettski's Avatar
The other thing you may want to consider given the effort you are going to.
Zionsville Autosport: BMW E39 - E38 Super Duty Cooling Kit
Riding in style
Newbie with a couple questions rickypr 3-Series (E46, E90) 1 09-03-2011 11:13 AM
Newbie here..got a couple Q's Rgomez87 3-Series (E36) 3 02-28-2007 12:50 PM
Couple Problems aotiko 3-Series (E36) 11 05-16-2005 10:33 PM
Couple Problems... E30M20b25 3-Series (E21, E30) 10 04-24-2005 04:53 AM
Couple questions from a newbie playtothebeat 5-Series (E12,E28, E34, E39, E60) 1 09-15-2003 09:20 AM
