New Rotors And Pads - BMW Forum - BimmerWerkz.com
Old 11-17-2004, 08:32 AM   #1 (permalink)
dberger's Avatar
dberger is an unknown quantity at this point
Thumbs up
On Monday, I just had new rotors and pads put on the front and when I stop they make a knocking or clicking sound. Is this normal for new pads and will go away or did the shop mess up somehow?
any advice will help.
dberger
dberger is offline   Reply With Quote
Old 11-17-2004, 11:14 AM   #2 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
You should not hear any noises, specially the ones you're describing!
I hope they installed the correct pads! Some of the pads have a tab which sticks out. Look for any wear on the tabs if you can. this will be an indication of rubbing.
LOS
Old 11-17-2004, 01:50 PM   #3 (permalink)
dberger's Avatar
LOS
[snapback]232628[/snapback]
Can I see the tab part of the pads without removing the tire? Where do I look for the tab?
Old 11-17-2004, 02:00 PM   #4 (permalink)
LOS
LOS's Avatar
Look at the brake pads. The tire may have to be removed for better clarity. If I were you, I would take it back to the shop.
LOS
Brakes Front Rotors And All Pads camnipotent 3-Series (E36) 4 07-26-2005 07:29 PM
"check Brake Lininings"????? vlad_ignatenko 5-Series (E12,E28, E34, E39, E60) 11 05-09-2005 12:03 AM
Need New Brake Pads And Rotors And Have Some ?'s elbee 3-Series (E46, E90) 4 12-18-2004 05:25 PM
Who makes bmw oe pads and rotors? ChewToy 3-Series (E46, E90) 2 12-30-2003 09:24 AM
Rear Brake Pads - do i need new rotors too? ChewToy 3-Series (E46, E90) 5 12-29-2003 10:01 AM
