New difficult cold start problem - BMW Forum - BimmerWerkz.com
Old 09-22-2008, 07:44 AM   #1 (permalink)
Blackcatecho is on a distinguished road
Well my saga continues. I have a 97 528i that just had a boat-load of work done. To keep a long story short it has the vf supercharger setup and now a new ipt performance trans. I ended up with a cracked head and that's now been fixed with new valves, guides, and seals and Dr. Vanos unit while it was all apart. The new problem is that when it's cold I have to crank it a couple-three time before it will start. Once it starts it runs like a dream and it will start up just fine through out the day. Once it sits over night again though it's the same story. No codes,and most all of my sensors have been replace within the last year(bought the car used and wanted to refurbish it to better than new). The fuel pump and filter are also new as are the plugs and coils. Injectors are also new as they came with the supercharger kit. All that stuff worked fine at cold start until the head work and trans replacement.
Blackcatecho is offline   Reply With Quote
Old 09-22-2008, 09:39 AM   #2 (permalink)
TxAg98 is on a distinguished road
Maybe a battery with more CCA???
TxAg98 is offline   Reply With Quote
Old 09-22-2008, 11:15 AM   #3 (permalink)
I figured if the battery was the problem then it would always have a hard start and not just at cold start right?
2001 325Ci Cold Start Problem! aanilust 3-Series (E46, E90) 0 01-20-2008 04:29 PM
325ic Cold Start Problem luckycat 3-Series (E21, E30) 1 12-20-2004 11:41 AM
Cold Start Throttle Problem Black_Tire M-Series (M1, M3, M5, M6) 2 09-27-2004 10:50 PM
Cold Start Problem arstaff 5-Series (E12,E28, E34, E39, E60) 2 09-27-2004 07:26 PM
Cold Start Problem (fuel Pressure Drop) BEX 3-Series (E36) 6 05-16-2004 07:35 PM
