new 520i with minor idle issues - BMW Forum - BimmerWerkz.com
post #1 of 6 (permalink) Old 05-05-2006, 09:57 AM Thread Starter
Morgenster's Avatar
Morgenster is on a distinguished road
used: Hi,
I posted earlier about my search for an e34 520i with m50 engine.
I found and bought one that has 260000 km on it.
The previous owner replaced the radiator, hoses, silentblocs in the rear and the MAF.
It drives real nice.
It has an LPG aspiration system which will save me tons of money at the pump. (I do about 1500 miles a month).
Something's bugging me a little though:
At starting (relatively cold or cold starts). Idle is fine at first, but after revving the first time idle can sometimes drop real low, like 400 rpm or even stall. That goes away after a few miles of driving, but even then idle is stable, but never really smooth and it looks as if the idle control valve can't decide on how far to open. So idle stable, but idle speed can vary abrubtly (never over 1K rpm).
I'm wondering now if this could be due to the throttle position sensor.
The bentley manual says the TPS is non-serviceable, but has anyone ever tried cleaning it?
I'm going to measure the resistance and voltage tomorrow at work.
Does anyone here know what else could be causing this?
Morgenster is offline
post #2 of 6 (permalink) Old 05-05-2006, 12:07 PM
tracetrimble is on a distinguished road
Clean the IAC if possible.
2002 540i sport auto
tracetrimble is offline
post #3 of 6 (permalink) Old 05-05-2006, 01:54 PM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute
Do yourself a favor and download the Bentley Manual pinned at the top of the 5 series forum. Most things that apply to the m50 525i are same for your car.
Torque is offline
post #4 of 6 (permalink) Old 05-05-2006, 11:07 PM
Sodium Chloride
saltshaker185's Avatar
saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold
clean out the ICV with an alcohol based cleaner and see if it does it anymore...
saltshaker185 is offline
post #5 of 6 (permalink) Old 05-06-2006, 04:34 AM Thread Starter
Morgenster's Avatar
Did you mean ICV?
It's the weirdest thing: the Bentley manual says you should be able to reach the ICV without removing the intake manifold, but I can't even see it in there.
Is it close to the throttle butterfly or elsewhere?
I'm probably going to replace a number of vacuum hoses anyway since they've likely had a rough time with LPG backfires from time to time. And add a backfire release valve to the intake system.
The Bentley manual is very helpful, but sometimes still a little lacking in illustration...
post #6 of 6 (permalink) Old 05-06-2006, 08:16 AM Thread Starter
Morgenster's Avatar
Just tested resistance between terminal 1 and 2 of the Throttle position sensor. With throttle fully closed I get 2K ohms instead of 1K.
Terminal 1 to ground doesn't read anything.
With throttle opening from closed to ful resistance does vary linearly from 2K to 5.6K ohms.
So to get back to my original question:
is this TPS faulty? and if not: why am I not getting voltage between terminal 1 and the engine ground wire with igntion on?
Do you guys think that swapping out the TPS for a new one will solve the problem even moderately?
Oh, and what's the partnumber?
Thanks a bunch!!!
OH, almost forgot: there's no surging idle thing going on. It just idles too low when cold (after the first tap on the accelarator) and idle speed changes in phases like as if the ECM is trying to adjust idle speed but doesn't get the right info. In between changes idle is constant.
Fuel issues? Car bogging! ReaverJam 3-Series (E21, E30) 5 10-04-2005 11:16 PM
Storage Issues offabroadway 3-Series (E21, E30) 6 08-09-2005 01:54 AM
Some Issues In My '91 520i Euro Spec backindauk 5-Series (E12,E28, E34, E39, E60) 16 05-15-2005 03:46 AM
Electrical Issues fireblade97rr 5-Series (E12,E28, E34, E39, E60) 5 10-17-2004 04:48 PM
2000 740i Issues vevro 1,6,7,8 - Series and Mini Cooper 1 04-21-2004 02:07 PM
