i tried searching the forum but didnt really find anything, i have a 99 540ia 63000 miles, just this morning my heater stopped working no matter what settings i have on the climate - i only get cold air no matter where i direct it, the fan and all the other buttons work but i only get cold air even when the engine is fully warmed up i get no difference, please help.
Originally posted by andymarshal@Nov 20 2004, 01:13 PM i tried searching the forum but didnt really find anything, i have a 99 540ia 63000 miles, just this morning my heater stopped working no matter what settings i have on the climate - i only get cold air no matter where i direct it, the fan and all the other buttons work but i only get cold air even when the engine is fully warmed up i get no difference, please help.
thanks
andy
[snapback]234239[/snapback]
Did you check your heater control valve in the fire wall area?
Originally posted by billB+Nov 20 2004, 02:11 PM--><div class='quotetop'>QUOTE(billB @ Nov 20 2004, 02:11 PM)</div><div class='quotemain'><!--QuoteBegin-andymarshal@Nov 20 2004, 01:13 PM i tried searching the forum but didnt really find anything, i have a 99 540ia 63000 miles, just this morning my heater stopped working no matter what settings i have on the climate - i only get cold air no matter where i direct it, the fan and all the other buttons work but i only get cold air even when the engine is fully warmed up i get no difference, please help.
thanks
andy
[snapback]234248[/snapback]
[/b][/quote]
thanks for the reply bill but i dont know what you mean when you say firewall and where would i find the heater control valve, sorry bill but as you probably guessed im not very technical
You may be facing one of the following:
1. As I mentioned earlier it can be as simple as a Heater valve manifested in a bad diaphragm.
2. It can be a temp sensor at either side.
3. It can be as bad as a problem with the Auto climate control unit itself either physical under the dash or logical in its programming.
As you can see the troubleshooting process can escalate from the least to the most complicated (thus more expensive) solutions.
P.S. Andy is it possible to get some help from a friend/relative/local mechanic who knows more about auto mechanics? As such you can pinpoint the exact problem through proper diagnostics. I’ll not feel so comfortable working on a complicated system like the 540 all by myself if I am not equipped with the proper knowledge; otherwise it may cost you more in terms of safety and money.
I am sorry if this is not much of a help and I wish you Good luck
Regards
billb
ok bill i found the problem, the dreaded crack in the rad left me with a dangerously low coolant level, however my obc never gave me a warning?
below is an email i sent to bmw customer service, i will keep you updated, get behind me on this boys
Hello, I have been the proud owner of a bmw 540 for the past few months and have been very pleased ith performance and build quality. However i have recently noticed a crack around the top section of the radiator which is slowly leaking coolant.
My car has 64000 miles on the clock and a full bmw service hiatory, surely a car of this calibre should not get trough a radiator at this age. Having performed a search on the internet for this problem it seems to be a common occurance on most e39's and is even considered on some web pages as a "common fault".
Having considered bmw as a high quality car manufacturer, i find it hard to beleive that this seems to be a common occurance especially on a low mileage car with a full bmw service history.
I would like to know what bmw's position on this problem.
Very Interesting....loosing all that coolant on a 540 without noticing a rising temp gauge (at least passing the half mark) and/or hearing an overworked aux. electrical cooling fan!!!
When you say the top section of the rad; I am assuming you mean the neck where the upper big hose is attached. It is made of plastic and you must be extremely careful when applying torque to tighten the hose over it. In fact over torque will crack it. I've seen it cracking once when a "smart mechanic" leaned on it with his left hand (while changing a fan belt).
Note: BMW can respond to your email/inquiry saying this crack is due to misuses not defects in their material. Also they may demand a physical inspection for final determination. Either way good luck and let us know of the final outcome.
