need help with oil pan screw!! - BMW Forum - BimmerWerkz.com
Old 03-15-2009, 01:32 AM   #1 (permalink)
Eric.Claire is on a distinguished road
I have all but completed my oil change but can't get that stupid screw to set right. Has anyone else had this problem and how can I get it back in. Its a 2003 530i. it doesnt seem like there is normal threads on the screw and the copper washer is strange.
Eric.Claire is offline   Reply With Quote
Old 03-15-2009, 01:46 AM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
what do you mean but the threads and washer does not look normal did you check the treads in the oil pan? hopfully there not stripped I know these things can be a PITA to get back in
1992 318i Coupe parts car
I am Captain Obvious
Old 03-15-2009, 01:49 AM   #3 (permalink)
it doesnt look striped it looks like it only may have a single thread on the screw and a couple on the inside of the pan. It gets hand tight but when any pressure is applied it loosens back up. I also am not sure which way the copper washer goes. It looks like it is different on both sides of the washer.
Old 03-15-2009, 01:53 AM   #4 (permalink)
is sounds like the pan or the bolt is stripped.... what kind of mechanical skills do you have?
Old 03-15-2009, 01:54 AM   #5 (permalink)
they are limited but I can't see any metal shavings where the bolt may be stripped.
Old 03-15-2009, 01:58 AM   #6 (permalink)
most likey they would has been flushed out with the oil... when the bolt is run all they way down you can still turn it correct?
Old 03-15-2009, 02:12 AM   #7 (permalink)
well that is the weird thing, I can get it hand tight but as soon as I but a socket to it it never gets tight. I was wondering if it had something to do with the washer. one side has a lip around the outside. My impression if it was stripped it would be stripped at the small end not the end with the bolt head. there is threading for a little over one complete rotation then nothing. It looks like a pretty unique boldt.
Old 03-15-2009, 02:26 AM   #8 (permalink)
... sounds like your bol is stripped is there anyway you can get a picture? it should have alot more then 1 thread!
Old 03-15-2009, 01:05 PM   #9 (permalink)
Car: 530i-2002 & E280-2007
rashid is on a distinguished road
Question: if the oil level is coming down every one-two months or every 15000 mk, is that normal in BMW or not?
rashid is offline   Reply With Quote
Old 03-15-2009, 04:22 PM   #10 (permalink)
how much is it going down?
busted oil pan k.sidlosky 3-Series (E21, E30) 7 02-03-2009 06:44 AM
Help....oil pan change? 89bmuh 3-Series (E21, E30) 6 01-20-2009 07:47 PM
How can i screw up an oil change JoeMadoo 3-Series (E21, E30) 8 09-16-2006 10:41 PM
Oil Pan flipsgonetopless 3-Series (E21, E30) 10 11-29-2004 05:59 PM
oil pan dfw325e 3-Series (E21, E30) 3 07-20-2004 07:29 PM
