Need Help Asap!!! - BMW Forum - BimmerWerkz.com
Old 05-23-2009, 03:49 PM   #1 (permalink)
RNH 524 is on a distinguished road
Need Help Asap!!!
I have an 98 528i BMW and yesterday i was in going threw the drive threw getting food and then i notice my car started to over heat. So i parked it for like 5 mins started it back up and it was normal then let it sit there for a min or 2 then it started to over heat again. So i turned it off let it sit for a little longer started it and it was back to normal so i was driving home and about 3 mins into driving it started to over heat alittle but then went back down. So pretty much when i drive it over heats then it'll cool down alittle then it'll over heat again its weird. I dont know anything about these kind of cars and i just got it last week. I was thinking it could be the thermostat sticking but the dude i got it from got a brand new thermostat, water pump, and clutch fan put in it the day i got it. And i also noticed when i start it up now theres lie ka dark gray of smoke coming from the exhuast. Any ideas ?!?!
Let me know THANK YOU!!!
RNH 524 is offline   Reply With Quote
Old 05-23-2009, 03:57 PM   #2 (permalink)
Is there any sign of oil in the coolant or vice versa? There could be a head gasket issue.
Old 05-23-2009, 04:01 PM   #3 (permalink)
See i went to check the oil yesterday but i couldnt find the dip stick... I know it might sound retard and i do know about cars but never with a BMW... And i looked at the coolant today and it looked perfectly fine.
Old 05-23-2009, 04:42 PM   #4 (permalink)
ANyone else ?
Old 05-23-2009, 05:58 PM   #5 (permalink)
The oil stick should have a red or orange finger pull ring handle. If there's coolant in the oil, it will show at the bottom of the dip stick.
Old 05-23-2009, 06:55 PM   #6 (permalink)
jayy781's Avatar
Car: 98, BMW 740i
jayy781 is on a distinguished road
what kinda gas are you putting in
jayy781 is offline   Reply With Quote
Old 05-23-2009, 08:04 PM   #7 (permalink)
Are you also sure all the new parts are working rightly?
Old 05-24-2009, 05:48 PM   #8 (permalink)
Oh i didnt check that because i thought that would be got the transmission because usually the stick for the transmission are red. But when i just went out and checked out i couldnt really tell. like it wasnt a milky color. But yeah all the parts are new you can tell they look new and you can see the new gaskets and the dude gave me a receipt. Also when you bleed your rad. are you susppose to add coolant while doing it ?
Old 05-24-2009, 06:58 PM   #9 (permalink)
The process can vary from car to car. I would make sure you know it for your car.
Old 05-25-2009, 01:14 PM   #10 (permalink)
Nah i found everything out. IT was just the cooling system everything is fine now. THANKS FOR ALL THE HELP EVERYONE!!!
Old 05-25-2009, 02:25 PM   #11 (permalink)
Great news!
Old 05-27-2009, 05:38 PM   #12 (permalink)
Ok so it started to do it again today... Did i do something wrong or what ? Its not running like crap or anything. I took it out of town and back yesterday with no problems. But i did notice a little bit of smoke like maybe half hour or so before it started to over heat. But the smoke was only there for like a min if that. It was low when i first opened it up and looked in there so i added some then started the car n then it started to overflow (the coolant) so i hurried up and open the bleeder screw and it took a min for the coolant to go but it was still overflowing so then once it did i put the cap back on and open bleeder screw back open and there was alot of stream/air coming out.
Old 05-27-2009, 07:22 PM   #13 (permalink)
I'd say there's air trapped in the system.
Old 05-27-2009, 08:56 PM   #14 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
Make sure to bleed the system with the nose of the car up with the heater on full blast and start with the system cold you will lose coolant as the system bleeds
1992 318i Coupe parts car
I am Captain Obvious
Need help, ASAP! Majkee 5-Series (E12,E28, E34, E39, E60) 3 09-02-2008 08:01 PM
Please Help ASAP! BeemerMan 3-Series (E36) 9 05-05-2006 10:27 PM
Ok, NOW what?? Need help asap! Danbot 3-Series (E21, E30) 6 03-15-2006 10:31 AM
Need Help Asap!!! 92_325i 3-Series (E36) 17 08-06-2005 12:31 PM
Need Some Help Asap! kayvan_pour 3-Series (E36) 0 05-23-2005 01:58 PM
