Need Help - BMW Forum - BimmerWerkz.com
Old 10-01-2011, 08:27 AM   #1 (permalink)
Ahsakid is on a distinguished road
Question Need Help
I have a 528e 1988 . dose anyone know what will cause it to shake at speeds between 40 and 60 mph and on applying the brakes. I had the tires balanced and I replaced the front rotors . It only shakes vigourously when I apply the brake and it get down to 60mph then it stop shaking at about 40mph .
Ahsakid is offline   Reply With Quote
Old 10-01-2011, 10:27 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Could be a Prop/drive-shaft balance issue, or even the centre-bearing on the prop !!
Just an idea my friend...
Another thought - Run the engine in neutral and rev and hold it in different rev areas, just to feel any vibrations... If none then this has eliminated engine balance and/or flywheel issue !
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 10-01-2011, 05:42 PM   #3 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Welcome to the Werkz
This is a reasonably common issue caused by worn front control arms and related steering components. A front end specialist shop will be familiar with the issue and be able to replace the parts then do an alignment. Its not too expensive normally.
Riding in style
Old 10-01-2011, 08:50 PM   #4 (permalink)
Thanks Guys I will try it out I will have a shop look at it
Old 10-02-2011, 08:03 AM   #5 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Good spot Brett... They really are common faults on BMWs !
Eso es todo!
BMW Part Market
New Member ?
