Nav Cd Won't Stop Ejecting! - BMW Forum - BimmerWerkz.com
Old 07-04-2005, 07:47 PM   #1 (permalink)
///Matt's Avatar
The CD for my navigation system keeps ejecting. I'll put it in and about 10 seconds later it will eject, rendering the GPS navigation useless....has anyone else had this problem before. I did about a year ago, but it went away. Any help would be appreciated...
regards,
P.S. I was thinking overheating....but that's just an idea...
Old 07-08-2005, 07:50 AM   #2 (permalink)
JoeE39 is an unknown quantity at this point
MKI or MKII navigation? Could be that the CD is dirty or scratched - try wiping it down and see if that helps. I had a similar problem before I upgraded to MKIV.
Joe
JoeE39 is offline   Reply With Quote
Old 07-10-2005, 05:09 PM   #3 (permalink)
///Matt's Avatar
It's the MkI GPS unit....The disc is perfectly clean, however after I popped the top off the unit, i saw that the CD was not even spinning....could the motor be out on it?
Old 07-11-2005, 12:30 AM   #4 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
[snapback]361298[/snapback]
Easy way to find out would just be to hook up a standard 12v battery to the terminals of the motor. If it spins, then the motor's ok.
Lindsay fan club member.
Old 07-11-2005, 09:24 AM   #5 (permalink)
tacroteau's Avatar
tacroteau can only hope to improve
Send a message via AIM to tacroteau
Originally posted by 528iUOND+Jul 11 2005, 01:30 AM--><div class='quotetop'>QUOTE(528iUOND @ Jul 11 2005, 01:30 AM)</div><div class='quotemain'><!--QuoteBegin-///Matt@Jul 10 2005, 06:09 PM
ITS NOT A 12v MOTOR!!! Thats an easy way to toast it for shure. Do the smart thing an put a multimeter on the leads, check for current, it you have it, you know the motor is toast.
[snapback]361412[/snapback]
[/b][/quote]
tacroteau is offline   Reply With Quote
To Nav or not to Nav? AngelEyes 3-Series (E46, E90) 2 10-27-2005 09:20 AM
Car Won't Stop! Throttle Stuck jetmax 3-Series (E36) 7 06-08-2005 02:45 PM
Noise at stop Mn97BMW 3-Series (E36) 3 08-25-2004 10:36 AM
325I won't start in heavy SUNLIGHT 325iconverted 3-Series (E21, E30) 3 07-09-2004 12:15 AM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
